no Send in algorithm FuzzWaWammyPre (149)?
Home Forums Products Rackmount no Send in algorithm FuzzWaWammyPre (149)?
Viewing 4 reply threads
    • #106435
      jfcharles
      Hi everyone,
      The drawing for this algorithm in the doc shows a send (S) right after the EQ. I can't find it when playing with the unit. Is it there?
      I tried to use the TRIM parameter in the EQ instead, but the implementation is not good for performance: when we change this parameter with an external, no audio xfade/audio line connects old and new values, and that results in clicks in the signal when we change the TRIM (usually that doesn't happen when the algorithm has a send).
      Is there another way to doing that?
      Thanks for you help,
      Jean-Francois.
    • #119039
      IDeangelis
      Hi JF
      the S can also be labeled MANUAL_PED. It's the same function and it's patched to EXT_1, which is assigned to Pedal 1 as factory default.
      best
      I
    • #119040
      jfcharles
      Thanks for the answer!
      Yes, it does work IF I set the EFFECT (in Parameters-> Pedal) to volume.
      Problem is: I want to use the wammy transposition fixed to -1200 for instance. To achieve that, I have to set the EFFECT to wammy, otherwise, I don't get any transposition, right?
      But when I set the EFFECT to wammy, then I can't control the "volume" anymore, right?
      Actually, as far as I understand, in this algorithm, there is a choice (eXclusive OR) between the volume, the wammy, and the wawa. Or what am I missing there?
      Thanks for your help!
      J-F
    • #130135
      IDeangelis
      Yep. You have to choose which fx is controlled by the pedal…either …or…or.
      You may place a second algorithm after this one, in series, and use its SEND for level control.
      best
      I
    • #130136
      jfcharles
      That's what I feared, thanks for the confirmation!
      J-F
