Hi, I was testing an aux switch pedal on the Timefactor to add switch functionality (the aux switch was a Boss FS-5L / using a mono cable)
After I tried I get no sound whatsoever from the Timefactor.
The display functionalty all seems to work normally, and the display responds to H9 Software as well – only… no sound.
What I allready tried is:
– Initializing the pedal – still no sound
– Updating software (no luck – cause I recently updated to the latest beta 5.2 – so I can’t select any software in direct updater)
Could the aux switch have muted something or in the worst case damaged something?
