Noise Gate setup via Android App.
Home Forums Products Stompboxes Noise Gate setup via Android App.
    • #115294
      Paradox
      Using the H9 Android app I’m unable to found the “Noise Gate” button, for example in the CrunchStation algo. Using the Windows app there is.
      Is there a way to modify the noise gate under Android app?
      Best regards,
      Bye
    • #151765
      bohan
      Paradox wrote:
      Using the H9 Android app I'm unable to found the "Noise Gate" button, for example in the CrunchStation algo. Using the Windows app there is.
      Could you attach a screenshot here to show where the Noise Gate is in the Windows app?
    • #151766
      Paradox
      I’ve resolved the mistery! In the Android app the gate button is only visible in vertical mode!! Not in landscape!! Because I use the landscape view all the time I’ve missed it.
      • #151828
        bohan
        Paradox wrote:
        I've resolved the mistery! In the Android app the gate button is only visible in vertical mode!! Not in landscape!! Because I use the landscape view all the time I've missed it.
        Thank you for your feedback. You may use the Tempo button in these algorithms in the landscape view for now. I've fixed this issue and used a Gate button instead in these non-tempo algorithms. This will be effective in the next update.
