Just letting you know of a new algorithm that we’ve just released. This time it’s a non-linear dynamic distortion called 14 Stage Wrap. This algorithm allows you to amplify the signal, but instead of clipping, the signal will wrap from positive full scale to negative full scale up to 14 times, and with 50dB or headroom, any signal remaining unwrapped can be kept clean, or can clip by increasing the output gain.
This algorithm is broadly similar to the Kurzweil VAST DSP block of the same name, though is more versatile.
