Noob Question: select Algos for presets.
Home Forums Products Stompboxes Noob Question: select Algos for presets.
Viewing 8 reply threads
    • #111087
      Bzerk
      Hi!
      Just got my H9 yesterday (works amazingly well in the FX loop of the Eleven Rack).
      I don't have a win/ios device, only android ;( For the moment, I try to tweak stuff by using the knobs and switch on the device.
      I have a few questions:
      I would like to create a preset. So far I start by editing for instance preset 1, It is based on the HALL algo, I would like some other algo, how can I switch the algorithm on this preset?
      Do I have to select a preset with the algo I want tu use, tune it, and save/overwrite the preset 01 ?
      In this case, is there a way to find a preset using the algo I want easily?
      Bonus question: If it works like that and I do something really stupid such as overwriting all the presets with the same preset, using a given algo, how could I create a preset with an other algo after that? (yeah, ok, really dumb).
      Sorry, those are probably really noob questions…
      Guillaume.
    • #124799
      gkellum
      Hi Guillaume,
      Yes, currently there is no way to directly select an algorithm on the H9.  So, you do have to select a preset with the algorithm you want to use, tune it, and save/overwrite another preset.  (It doesn't have to be a preset at the same position.  You can modify preset 88 and save it to position 12.)  There are a couple of different ways you could go about finding a preset with a certain algorithm.  If you're looking at a loaded preset on the H9, pressing the preset button will show you the name of the algorithm used by the preset.  Also, I've also copied below a table showing the mapping  from the preset name to the algorithm used;  this will also be posted on the product page for the H9 soon, although it isn't there right now.
      >  If it works like that and I do something really stupid such as overwriting all the presets with the same > preset, using a given algo, how could I create a preset with an other algo after that?
      Actually, this is a very good question.  You can restore all the factory presets by holding the right footswitch and the wheel down when the H9 is restarting, but this will wipe out all of your own presets.  Or you could transfer over a preset with that algorithm using H9 Control;  unfortunately, we don't support Android yet, but there are builds of iOS, Mac OS X, and Windows.  Ideally you would be able to select an algorithm on the H9's interface directly, but this isn't currently supported.  I'm maintaining a wish list of H9 features though, and I've marked this down as a feature request.
      PRESET
      ALGORITHM
      1 ULTRATAP
      ULTRATAP
      2 BALLERINA
      H910 H949
      3 WARMTH
      CHORUS
      4 LENNON SLAP
      TAPE ECHO
      5 1984PANAMA
      H910 H949
      6 EARTH HALL
      HALL
      7 I WALK ALONE
      TREMOLOPAN
      8 STREETS
      VINTAGE DELAY
      9 SHIMMER
      SHIMMER
      10 BATMAN
      ULTRATAP
      11 CLASSIC CRYSTALS
      CRYSTALS
      12 POLYMODELICIOUS
      CHORUS
      13 FIBONACCI TAPE
      TAPE ECHO
      14 WOMENINLOVE
      H910 H949
      15 KUBRIX
      HALL
      16 TUMBLEWEED TREM
      TREMOLOPAN
      17 AMBIENT VINTAGE
      VINTAGE DELAY
      18 MOUNTAINS
      SHIMMER
      19 BOUNCING BALL
      ULTRATAP
      20 1984LEGS
      H910 H949
      21 SPINNING
      CHORUS
      22 TAPE FOR VOCALS
      TAPE ECHO
      23 3 OCTAVE RANGE
      H910 H949
      24 CORRIDORS
      HALL
      25 RAMPCHOPPER
      TREMOLOPAN
      26 FOUNDIT
      VINTAGE DELAY
      27 IRONWORX
      SHIMMER
      28 GHOSTHUNTER
      ULTRATAP
      29 SEAGULLS
      CRYSTALS
      30 PULSATING
      CHORUS
      31 CLASSIC SLAP
      TAPE ECHO
      32 AREYOUTHERE
      CRYSTALS
      33 DARK CAVE
      HALL
      34 SQUARE CHOPPER
      TREMOLOPAN
      35 LONG VINTAGE H9
      VINTAGE DELAY
      36 TOUCHED BY AN H9
      SHIMMER
      37 MOSQUITO
      ULTRATAP
      38 DISAPPEARING HAL
      ULTRATAP
      39 70S GUITAR CHORU
      CHORUS
      40 RECORD HEAD
      TAPE ECHO
      41 POWERCHORD
      H910 H949
      42 DELAYEDPLATE
      HALL
      43 HELLS GATE
      SHIMMER
      44 VINTAGE VOCAL
      VINTAGE DELAY
      45 SIZE MATTERS
      SHIMMER
      46 STUTTER
      ULTRATAP
      47 STEAMPUNK
      CRYSTALS
      48 CHORUS BUMPS
      CHORUS
      49 BE WOWED
      TAPE ECHO
      50 SHATTER
      H910 H949
      51 CARNEGIE HALL
      HALL
      52 SPECIAL AGENT FA
      TREMOLOPAN
      53 ROTTEN OLD DELAY
      VINTAGE DELAY
      54 SNEAKY VERB
      SHIMMER
      55 SLOWING DOWN
      ULTRATAP
      56 FROM A BAD DREAM
      CRYSTALS
      57 LIQUID SWEETENER
      CHORUS
      58 MULTI SLAP
      TAPE ECHO
      59 PHOTON BEAM
      H910 H949
      60 DOOM CHAMBER
      HALL
      61 ULTRASWELL
      ULTRATAP
      62 LO-REZ TRAIL
      VINTAGE DELAY
      63 QUASAR
      SHIMMER
      64 ZIPPERVERB
      ULTRATAP
      65 REVERSE DETUNE E
      CRYSTALS
      66 BIG CLONE
      CHORUS
      67 REELTOREEL
      TAPE ECHO
      68 INSANITY BUILD
      H910 H949
      69 PHANTOM VERB
      HALL
      70 FLUTTER TREM
      TREMOLOPAN
      71 SLAPVINTAGE
      VINTAGE DELAY
      72 DARK ANGELS
      SHIMMER
      73 CHOPHALL
      ULTRATAP
      74 PITCH A LA V
      CRYSTALS
      75 CLASSIC CHORUS
      VINTAGE DELAY
      76 FLUTTERWOW
      TAPE ECHO
      77 RISING SWIM
      H910 H949
      78 VAPOR TRAIL
      HALL
      79 PULSING TREM
      TREMOLOPAN
      80 LONG OLD DELAYS
      VINTAGE DELAY
      81 NEROS ASCENT
      SHIMMER
      82 SIX PULSING
      ULTRATAP
      83 REVERSELOWS
      CRYSTALS
      84 HUH FLANGE
      ULTRATAP
      85 UBETTERRUN
      VINTAGE DELAY
      86 BACKING VOCAL
      H910 H949
      87 PANOROMANCE
      HALL
      88 PANNING TREMO
      TREMOLOPAN
      89 NICE OLD ECHOES
      VINTAGE DELAY
      90 GUNSHOT SNARE
      SHIMMER
      91 FOLLOW ME
      ULTRATAP
      92 CLOCKWORX
      ULTRATAP
      93 NANO STUDDER
      ULTRATAP
      94 TAPEDRONE
      TAPE ECHO
      95 WEIRDBASS
      CRYSTALS
      96 SYNTH GHOSTS
      ULTRATAP
      97 BULLFROG
      ULTRATAP
      98 TAPSLAP
      ULTRATAP
      99 GLITCHTRIGGER
      ULTRATAP
    • #124800
      Bzerk
      Thank you very much for your answer.
      I saw the list of preset, there are a lot I really want… Can I use someone else ios device to buy an algo?
      Will my device tied to the iphone? Or the algo tied to the iphone?
      Or is the iphone just a way to pay then the algo is tied to my device and account and if somedays you release H9 control for android I will seed everything I already paid on the android app?
      If it is the case, I would be great, I could borrow a ios device while waiting to use H9 control on my phone and tablet (android is quite popular here, in europe).
    • #135619
      gkellum
      Yes, you can use someone else's iOS device to buy an algorithm.  Apple's iTunes Connect is just a way to pay for an algorithm.  The information about the purchase goes to Eventide's server, and the algorithm is connected to your Eventide account.  So, yes, when we later release an Android app, when you connect to an H9, it will ask you for your Eventide account information and it will go and get all of your purchased algorithms from Eventide and show them on your Android device.  This is the way it works on the desktop versions of H9 Control as well…
    • #135620
      Bzerk
      Great!
      Thank you very much for your answers. I will try to borrow an ios device today.
    • #124801
      wilkinsi
      Now if we could have these presets added to the Eclipse… Wink
    • #135621
      gkellum
      Bzerk:
      Did you mean you saw the list of algorithms and there were a lot that you want?  Because the list of presets that I posted above are all of the presets that come standard with an H9.  You should have all of those presets already…
    • #135622
      Bzerk
      Sorry, I meant algorithms… I borrowed an iphone and got the free algo yesterday. I choose the Quadravox, Amazing!
      I saw that there is some documentation about the midi sysex protocol for the factor pedals. Is it the same protocol for the H9 or will you release some doc about it?
      I found a nice trick, I configured my FCB 1010 to help in tweaking the parameters for the H9.
      Each of the 10 footswich select a parameter (from  KB0 to KB9) and the right expression pedal set the value of the choosen parameter. It works!
      Now, If I have time, I will write a small software to do it with my tablet. It will be more convenient than on the device itself (but if your android soft is around the corner, I'd rather not waste my time on that).
      Having such a good and documented midi implementation is really cool.
      I wrote ElevenHack, a free rig loader to the Eleven Rack, and I can tell you that guessing the whole sysex protocol and the binary file format had been a nightmare. When I saw that you document even your sysex messages, I was ecstatic 🙂
      I used the H9 for the first time with my band yesterday…  made a big impression !.
    • #135623
      gkellum
      Bzerk:
      That's really clever. I wouldn't have thought that would be possible with a FCB 1010.
      The H9 supports the same MIDI protocol as the Factor pedals;  so that document you found is the best source of documentation for it.  We'll have to copy that over to the documentation section for the H9 and check to see if it needs any updating.
      H9 Control itself uses a different MIDI sysex protocol, but the protocol H9 Control uses is encrypted to make it impossible for anyone to connect to your device over Bluetooth and start messing with it. Because of the encryption, it's not possible for other applications to use it, but I don't think there would be any advantage to using it anyway over the existing MIDI sysex protocol.
      Bzerk:
      I'm not sure how you would define "around the corner", but we aren't working on the Android version right now.  The next release is going to have the in app store functionality for the desktop builds of H9 Control and it's going to have a new algorithm.
