Hi
I'm having a lot of fun with the omnipressor, but one thing is holding me back:
The "enter" key command which is the play main control button in nearly every daw out there, is also assigned to skipping the presets in Omnipressor.
This is quite hindering because you need to play and skip trough the song to adjust compressor settings and every time the omnipressor skips trough the presets unwillingly. Is there a way to turn this off?
