Home › Forums › Products › Stompboxes › One Control OC10 > H9 Core > EVH5150iii50watt
Hi all,
What is the best way to set up/link devices using MIDI cables?
I currently Just use one cable straight from the MIDI out of my OC10 into the EVH head and it works perfectly.
Luke
If you set up the H9 as "MIDI Thru", and wire it just as you posted above, it should work fine. Just make sure your MIDI receive channels are different between the EVH head an the H9 and you should be good to go.
