Home › Forums › Products › Stompboxes › One exp pedal with 2 H9’s
Is it possible to use a stereo Y cable and control two H9's with 1 pedal?
I've heard of other users doing that with an aux switch. I believe it should work… We've never tried that in the office though…
Well I've got a core on the way so I hope it works. I want to set one on compressor and sweep the volume, second on delay and sweep the mix. Then heel down will be dry crunch, roll towards toe for quick lead fills.
It will work, but it becomes your responsibility to avoid ground loops.
