Home › Forums › Products › Stompboxes › One Expression pedal to control 2 Eventide pedals
April 1, 2019 at 7:38 pm #115259birdland75Participant
I currently have H9 and a Timefactor on my board. I control involved with a boss ES5. I can make Midi preset changes in use the tap tempo on the boss perfectly.
I would like to hook up expression pedal to one of the two pedals and control both, mainly the mix. Since they are both set to through I’m not sure I can set that up . Anyone have experience doing that ? -
April 1, 2019 at 8:02 pm #151616brockParticipant
No experience with the Boss, but can’t you hook up the expression pedal to it, instead? The H9 & TimeFactor can remain set to Thru. Could be a problem if the TF & H9 have to be on different MIDI Channels, though.
April 2, 2019 at 2:32 am #151619davebrubakerParticipant
I use the Boss EV-30 expression pedal with two outputs running into two H9’s. A simple $99.00 solution. The midi expresion from my ES-8 is problematic into the H9’s.
April 3, 2019 at 9:19 pm #151629Birdland75 wrote:I currently have H9 and a Timefactor on my board. I control involved with a boss ES5. I can make Midi preset changes in use the tap tempo on the boss perfectly. I would like to hook up expression pedal to one of the two pedals and control both, mainly the mix. Since they are both set to through I’m not sure I can set that up . Anyone have experience doing that?
Two ways to achieve this:
First way: Plug your expression pedal to your ES5, and map it to a MIDI CC message on your ES5, so it can send this CC to two H9s, and map this CC to control volumes on both H9s.
Second way: Plug your expression pedal to the first H9:
- Set first H9's midi output to MERGE (so it can thru and transmit its own MIDI messages).
- Turn on the first H9's MIDI CC XMT
- Set the first H9's MIDI XMT CC mapping for the expression pedal in the XMT CC menu (by default it is CC 11)
- Map this CC message to Expression pedal on the second H9
- Now you may use your expression pedal on both H9s. If you'd like to use is to control the input or output volume, you may set it on a preset by preset basis. You may do it in H9 Control by clicking "More" and "EXP controls input volume" or "EXP controls output volume"
