Home › Forums › Products › Rackmount › Only getting effects out of one channel?
I`m getting the effects out of one side and the signal is dry out the other. Any Help won;ld be great . Thanks
Most likely you have some cable problems. More all the left cables to the right and vice-versa.
If this does not do it, you may have some settings confused. Try a CLEAR SETUP to return the unit to the default settings.
Other considerations – output set to mono, routing of effects set to parallel or dual mono. If not a cable issue, then perhaps one return channel on the mixer is muted.
