Home › Forums › Products › Stompboxes › Order in the chain signal
Hello, I have a time factor and a space. Is there a difinitive order in the signal path they should go?
Jeff
Generally Reverb & Delay effects sounds best at the end f the signal chain after distortion or your preamp but some it's really all down to taste & the effect you want to achieve.
But there really is no definite answer. 😉
Timefactor and then Space at the end of the line. I found no better way, sounds superb!!
