Home › Forums › Products › Stompboxes › original power adapter delivering 12v
June 3, 2010 at 10:09 pm #107114
dda
MemberHi all,
I bought a Timefactor a couple of weeks ago. No complains about it, great tones, works fine, everything is ok with it.
For a stupid reason I decided to measure the output of the power adapter supplied with the stompbox (european version as mentionned on the packaging) with my multimeter and read : 12v.I double checked the measure (even checked my multimeter and my power outlet), and confirm thee power adapter delivers 12v instead of 9v to the Timefactor.
Even if the unit doesn't seem to complain about it after 2 weeks of use, is this "over feeding" likely to harm the stompbox after more times ?
June 3, 2010 at 10:37 pm #120477
I think this shows the danger of test equipment …
You don't say under what conditions you are measuring the output. I suspect it may be with no load, in which case the voltage would certainly be higher than you would expect. If you were to measure it when connected to a working TF, it would be noticeably lower.
Beyond this, the specified values usually have margins to cope with a range of actual operating conditions. For example, our power supplies were chosen to be able to operate over line voltages between 100 and 130V (USA model) – this is one reason why they are bigger than many would like.
June 4, 2010 at 7:36 pm #120478
oyarsa
ParticipantNick,
Are the USA power supplies for the TF regulated or non-regulated?
THanks
June 4, 2010 at 8:09 pm #131707
They're unregulated – the regulation is done inside the TF.
June 17, 2010 at 7:40 pm #120513
mak
MemberSo is it feasible to run TF from the 12V outlet of a Fuel Tank to take advantage of the high current availability? I accept it is outside the recommended ideal, but some quick sums would indicate wall voltage fluctuations of approx 30 volts worldwide means the pedal should be able to handle it??
Thanks for any advice
June 17, 2010 at 7:45 pm #120514
mak
MemberBTW FWIW my factory supply measures 15.8 unloaded!!
Cheers
Vino
June 17, 2010 at 7:52 pm #131725
FWIW = not much. The loaded value is the thing.
June 17, 2010 at 8:00 pm #131726
mak:
T-Rex does not publish complete specs for their power supplies so I can't give you a clear answer. They do show pictures of TF and MF being powered by their products in their manuals – you should probably ask them …..
June 17, 2010 at 8:03 pm #131727
mak
Memberthanks for the quick reply Nick.
Point taken-but- if a factory supply @ approx 1amp rating drops from 15V to 9V under load, then a 3rd party device rated @500ma will most likely easily drop from 12V to 9V under load.
I'm only pursuing this like everyone else to find a more compact – and safer solution for my new pedal board.
Having 240AC floating around with AC plugs, sockets etc doesn't seem to me to be as optimal as an integrated, sealed tank for the time that guy drops the glass of beer on my board.
Yeah I know- I need to play in more classy venues!!!
Cheers
Vino
June 17, 2010 at 8:04 pm #131728
mak
MemberOK- I'll shoot off an email to T-Rex
Thanks
Vino
June 17, 2010 at 8:41 pm #131729
mak:
Not necessarily – if it is regulated it may only drop a few mV. If it is not, its off-load voltage may be 15-20V.
When using a 12V supply, regulation is the issue, as things inside a 'Factor start exceeding their ratings above about 15V.
