Orville beginners question..?!?
Home › Forums › Products › Rackmount › Orville beginners question..?!?
Viewing 4 reply threads
    • #106179
      vibeunit
        Hi guys this is my first post over here!,
        I've just bought a orville on Ebay, and I was wondering If its possible
        to 'sum' to one input (guitar) even though most program are stereo input or more and
        If its possible to sum the presets to just a stereo output pair even If some programs have like four audio outputs..? And is this possible globally or only for one preset? Because I just wanna use like this for now…
        Somehow I don't get it with the routing, I guess..arghh
        I've searched for this and I only got into the DSP routings and such…
        Can somebody help me out on this..?
        The Orville is so much more complicated than the Timefactory I've been using lately.. 🙂
        The Orville sounds so incredible by the way, really inspiring..
        Greetings, a guitarplayer from Holland
      • #118502
           Most of this is possible. BUT, you will have to learn the routing.
          To mono the input, go to SETUP/DSP A (or B as appropriate) and point the IN1,2 etc to your source (probably "analog in 1"). This will feed analog in 1 to all the preset inputs.
          Monoing the output is a bit harder. To combine 2 outputs go to SETUP/OUTPUTS and set (say) ANA1 to both "DSP A out 1" and "DSP A out 2". This will sum 2 of the preset outputs and feed them to analog out 1.
          If you want to mix 4 outputs as you suggest, you will have to load a mixer preset into DSPB and feed it from DSP A.
          Basically, you have to read the manual. It's character building. Sorry.
        • #118503
          vibeunit
            Wow! thanks for the quick reply Nickrose! I have searched & read the manual for this stuff but somehow
            your explanation got me there a once.. 😉
            Only one thing, I didn't mean 'all' to a mono output, just a stereo pair for all four outputs…
          • #129824
            richardt
              Import the Quad output preset into VSIG, add a stereo mixer, add 4 inputs to the mixer panned as stero pairs, connect the 4 inputs to the mixer, and connect the mixer outs to inputs 1 and 2. Export back to Orville. Takes about 30 seconds.
            • #129828
              Achtung!
              Quad presets use quad mixer with front/rear AND left/right panning.
              You may just add a stereo mixer in Vsig and make it 4 channels inputs. Use the panning to choose which output a signal should come off from.
              I
