Orville Dry/Wet
Home › Forums › Products › Rackmount › Orville Dry/Wet
Viewing 3 reply threads
    • #106992
      dood
        Hello (excuse me in advance for my bad frenchy-english)
        Im a newbie with my orville. I see, in the level, section that i can change the dry/wet ratio. But this parametter is globaly seted (for all the presets).
        Is it possible to set the dry/wet ratio on each preset independently?
        Thanks in advance
        dood
      • #120220
        Hi dood
        the dry/wet ratio can only be set for the system, not for the single preset.
        A few presets may have separated dry and wet levels. Others may be modded using Vsigfile editor.
        Or you could route dry and wet signals thru Orville oitputs, using the routing configuration page.
        Then using MIDI CC messages you could remote levels settings.
        all the best
        Italo
      • #120222
        dood
          Thank you. I try to make my own presets with vsig. It takes a lot of time but it works very well!! (this soft is very incredible, but very difficult to use for a newb).
          I owned the orville 3 days ago, and I'm total in love.
          Another question, does exist vsig files to import stompboxes presets in my orville (pitch factor, time factor, mod factor)?
          Bye
          dood
        • #131395
          Hi dood
          take your time with Vsig, from small to large….in time. You can do wonders with it.
          Stompboxes presets cannot be imported on Orville. They are not supported.
          have fun
          I
