Os Mavericks
Home Forums Products Rackmount Os Mavericks
Viewing 18 reply threads
    • #111319
      I was wondering if the H8000fw drivers work with os Mavericks ?
      Thank you
    • #125250
        We believe that they do, but have not heavily tested them.
      • #125251
        If Mavericks works,
        1. what OS in the H8000FW is necessary and
        2. would it be possible to connect it to a MacBook Air with Thunderbolt?
      • #136070
          Best to use the latest OS. But, this does not affect Mavericks – you should use the latest OSX drivers (from Web Site).
          H8000FW does not support Thunderbolt. You could try a Thunderbolt-FireWire adaptor, but because of driver issues it is possible that this will not work. We will invest the massive sum of $29 and give it a try.
        • #126233
          lbonemsk
            That question is actual for me too. I`ve got macbook with thunderbolt (thunderbolt to firewire 800 adapter, and firewire 800 to firewire 400 cable) and OS 10.9.3. H8000 shows that firewire is not connected ( in setup menu, but light on the back panel is on), and Eventide Control Panel doesn`t see it as well. Is there any way to make it works that way (through thunderbolt) or will you work on it ?
          • #137036
            pisco
              Hi
              I consider swaping from windows to Mac OS (Mac mini with Firewire). Can you confirm that the available driver for the H8000FW run with Mac OS X Mavericks?
              nickrose:
              Does the Thunderbolt-to-Firewire adapter work with the H8000FW? You announced testing in january.
              thanks and
              (BTW: I missed my quick reply, sorry if I posted twice 😉
              regards
            • #137037
                pisco:
                It does.
                pisco:
                No results yet. I'll ask them to try harder.
              • #137066
                pisco
                  thanks for the answer. Any new about the thunderbolt adapter?
                • #137341
                  ThreeFingersOfLove
                    Could Eventide give an honest answer as to whether the Firewire-Thunderbolt adaptor will work with the H8000-FW? I don't think it's too much to ask for.
                  • #137343
                      So far we have not got it to work. Sorry. We'll keep on it.
                    • #137344
                      ThreeFingersOfLove
                        Well, if it doesn't work, that pretty much will render the H8000-FW useless as an audio interface (especially with new Apple computers)…
                      • #137345
                          As I said, we're looking into it.
                        • #137381
                          ThreeFingersOfLove
                            Nick, did you have any luck with this? Also can you tell whether the driver for the H8000-FW will function properly with Parallels Desktop? I mean if Eventide doesn't release a driver for Yosemite, maybe I can install an older OS (such as Mavericks, Mountain Lion, and so on) by using Parallels. Will it work?
                          • #137383
                              We now believe that it works, but I've not heard from our test guy. I'll harass him a bit.
                              As for Parallels Desktop, I have no idea. Maybe someone can try it and let us know.
                            • #137386
                              doesn't work, but it would be great if it did
                            • #137393
                                ThreeFingersOfLove:
                                Honestly, it does work.
                                We fooled ourselves at first by using an iMac which had both FW and Thunderbolt – if you have two FWs, there is confusion. But, if you have FW you will not be needing the adaptor, so I'm not going to try and understand this.
                              • #137396
                                ThreeFingersOfLove
                                  I have 2 RME Fireface 800, these have the Firewire 800 port. The H8000-FW has two Firewire ports and these are 400 type. If I am good to go with the Thunderbolt-Firewire cable then I might as well sell the RMEs and finance one more H8000-FW. I am asking because I am in the process of buying a 2014 iMac, these only have Thunderbolt and I am not interested in investing in another audio interface if the H8000-FW works with no problems.
                                • #137397
                                    You'll also need 800 to 400 cables/adaptors to connect to the H8000.
                                    You'll want to try it out before dumping your RMEs, but we don't anticipate any problems.
                                  • #137475
                                    pisco
                                      chonnnnn:
                                      What did you mean? The Thunderbolt to Firewire-Adapter or the Workarround with Parallels?
                                      regards
