February 23, 2009 at 6:09 pm #106074
lightsong
ParticipantHi,
After I press yes to run the update I get a message:
Autoexec: bad file cmds.txt
Press any key to continue
Then: (E1) Can't Explain
I followed theupdate instructions and have done this 5 times with the same result.
Can you help?
Thanks,
John
February 23, 2009 at 6:22 pm #118304
Sounds like a card problem. Try another card, preferably below 2GB and not previously used.
February 23, 2009 at 7:10 pm #118305
lightsong
ParticipantThanks Nick – I've reformatted two cards – 256MB and 96MB – with the same results. They both had been previously used so maybe a new fresh card is necessary. I have many CF cards but all are used except a 4GB card.
John
February 24, 2009 at 8:20 pm #118310
lightsong
ParticipantThanks again Nick – a new 2GB card worked.
John
March 11, 2009 at 5:34 pm #129487
natrik
MemberHi,
After I press yes to run the update I get a message:Failure (E4004)
(E4004) bad_vpp
Can you help??
Thanks.
March 11, 2009 at 5:43 pm #129488
lightsong
ParticipantThe only thing that would work for me was to use a fresh, never used card. A 2GB card worked for me. Something smaller may also work.
JT
March 11, 2009 at 5:46 pm #129489
It would be helpful if you would say which product this is and what update you are trying to install.
However, judging from the message, it looks as though it is possibly a hardware problem. I would suggest that you retry the operation a few times, and if not successful, the unit should probably go for service.
March 11, 2009 at 6:29 pm #129490
natrik
MemberI'm tried to instal V5.22 Software Update for H7600, 10 times.
