Outputs differences
Home Forums Products Rackmount Outputs differences
    • #105473
      I saw on the presets manuals of the h7600 and h8000 that the 8000 contains all the presets of the 7600.But all those presets in the 8000 has summed in and quad out.I will not use instantly quad speakers,so what can i do to bring them back in stereo out?Using a mixer in Vsig?But sure are they the same algorithm with only splitted outputs or they're different??
      Thanks
      AleDreams
    • #117190
         You can use the output routing on the H8000 to sum two channels to each of the unit's outputs.
        So, you should be able to convert the H8000 from quad out to stereo out without editing the presets.
