Parametric EQ + low pass and high pass filters algo all in one?
Home Forums Products Rackmount Parametric EQ + low pass and high pass filters algo all in one?
    • #161301
      J20056
      I am trying to emulate the great EQ plugin from Logic whereby you can specify whether each of the 5 components is either a low pass, high pass (and specify slope) shelf or conventional Q-based EQ around a certain frequency. I cannot find any algo that combines pass filters and EQ in one algo, in fact I can’t even find an algo that allows low pass and high pass jointly that works (just posted about 4 filter algo not working). Is there any algo I may have missed?
    • #161337
      I’ve been looking into some EQ algorithms that you may like as a substitute for 1416 Four Filters, please see below:
      Low Cut / High Cut Algorithms:
      1240 DP_St.EQ45
      1140 St.Compr > EQ45 (same alg as above + compressor)
      1241 DP_St.EQ65
      1141 St  Compr > EQ65 (same alg as above + compressor)
      7851 Sfx Filter/Compress (needs some tweaking from default preset but can work well as a simple low cut / high cut / compressor)
      Low Pass / High Pass Algorithms:
      1218 Stage Parametric (dual 4 band EQ, selectable band pass / low pass / high pass for bands 1 and 4)
      3222 Compr>3Band 8ch (this is 8 mono instances of compressor + EQ)
