Peak led always lit on H9
Home › Forums › Products › Stompboxes › Peak led always lit on H9
    • #115172
      patroclo75
        it happens sometimes that the peak led on my h9 remains permanently lit and I have to switch off and on the unit to reset it. Is it a known issue?
        Thanks,
      • #151090
          It's not a known issue. You could try unplugging the input tand/or output to see if it goes off – if it does, it would suggest some kind of feedback loop.
          Otherwise, you could send it in to be repaired, but you may not consider it worth the effort.
