Pedal Loses Power when Plugged into Amp
Home Forums Products Stompboxes Pedal Loses Power when Plugged into Amp
Viewing 0 reply threads
    • #112386
      jgurley22
      When I plug my pedalboard in, my Timefactor turns on as normal but when I plug the board into the amp the Timefactor immediately turns off. This is try in isolation as well as in the pedal chain. I can plug the cables into the input and output jacks and the power is fine. Plug it into an amp and it dies immediately. Is there some sort of internal feature making the pedal think there is going to be a power surge. I have ones this pedal for over 5 years with no problem until this morning.
