Pedal Order
Home Forums Products Stompboxes Pedal Order
Viewing 4 reply threads
    • #106583
      thejay
      I have both the ModFactor and TimeFactor. I will be soon adding the PitchFactor too (very excited!), which order should these effects go in? Does it matter?
    • #119361
      achaput
      There is no wrong way to connect them, but a good way to start would be PF->MF->TF.
      Try this factory preset combo:
      PF 3:2  -> MF 6:2 -> TF 1:2
      It sounds like an organ!
    • #119363
      thejay
      Cool, I will give that a try!
    • #130477
      IDeangelis
      Definitely Pitch Factor first as other fx placed in front of it *may* interfere with its pitch detection. Then MF > TF or TF > MF is a more open choice, depending on how you prefer modulation to interact with delays. Trying both orders w/same presets is what will make your ear decide….
      cheers
      I
    • #130479
      Har
      Aginst common wisdom as I tend to steer more into the ambient/dark-ambient/experiemental areas, I have my PitchFactor after most of my modulation pedals and even after one of my reverb units, then followed by chorus, and ending with other delay/looping pedals and rack units.
      I actually like the degree of unpredictable, occasionally glitchy oddness having things like reverb before the PF can create. Smile
