Pedal power 2 and H9
Home Forums Products Stompboxes Pedal power 2 and H9
Viewing 4 reply threads
    • #111176
      theryanpaul
        Has anyone tried powering an h9 with the current doubler cable running out of a line6 output and a normal output so like out of 6+7?
        it would be awesome to power it without using the courtesy outlet.
      • #124969
        rdnzl
          Hello there
          I have a similar question: which power pedal is known to work well with the h9?
          Cheers
        • #124970
          theryanpaul
            So I found out that the Pedal Power 4×4 works the best since there are 4 dedicated outputs with 400ma each. That is what I am getting to run my two h9s and the rest of my board. Hope this helps!
          • #136615
            chaosnone
              Eventide's site say the H9 pedal requires 500mA.  Are you saying that it is working for you running through the 400mA plug?
            • #146931
              xdadex
                did this ever get resolved? 400ma enough to power it? eh?
