Pedal Power Digital Supply.
Home Forums Products Stompboxes Pedal Power Digital Supply.
Viewing 8 reply threads
    • #111577
      fahrner
      In the Voodoo Lab manual, it is recommended to run Eventide pedals at 12 Volts using the 400 mA outputs. It goes so far to say that this does not match the supplied Eventide adapter but does power the pedals correctly.
      Is this true? Why would bit be OK to run these 9 V pedals at 12 Volts?
    • #125811
      You should probably ask Mr Voodoo. My guess is that he considers the 12V output to be within the acceptable range of a 9V pedal – if it was stable it would be OK.
    • #125812
      fahrner
      Thank you for the quick reply. Was just looking at the Eventide PF2 and it looks that it powers the Eventide pedals at 12 Volts as well. Is there something lacking in the Pedal Power Digital or some magic in the PF2 that makes it different? Thanks for your help. It's important for me to get this right.
    • #136549
      Obviously we can only advise on the use of Eventide products. Questions about other products should go to their manufacturers.
      That said, the pedal's current requirements reduce at higher voltages, but if the voltage gets beyond a certain point, even for a fraction of a second, it may cause damage. So, a stable well regulated 12V at 400mA may be effectively the same as 9V at 500mA. Note that a poorly regulated 9V may exceed 12V, which is OK, while a poorly regulated 12V may exceed 16V, which would probably cause damage. You can see why we don't want people to experiment with these things.
    • #125933
      gigi
      hi there 🙂
      without opening a new thread, I wonder if I can use PowerFactor with H9, since H9 requires 500mA, while PF has max 400 on each spot :/
      thank you 🙂
    • #125934
      badmelonfarmer
      Yes you can.
      the PowerFactor actually uses 12v to power the Factor pedal and H9's
    • #136648
      gigi
      badmelonfarmer:
      Yes you can.
      so, since I'm not into those kind of things, I can use 9v and 500mA or 12v and 400mA?
      is that right?
    • #136652
      badmelonfarmer
      Yes, the supplied Wall Wart is 9v 500 mA and the connections on the PowerFactor at 12v 400mA
      off the top of my head
    • #136673
      gigi
      so, those solutions are pretty equivalent, right?
      of course I'm talking about well regulated power supplies 🙂
