September 2, 2020 at 1:12 am #116074
Hi everyone –
I’m experiencing some weird behavior when using Pendulate with MPE enabled & controlling via a Linnstrument & ContinuuMini. It seems that after holding down a note, many times triggering a new note doesn’t work until I attempt it several times. Also, some notes hang for a long time after being released on the MPE controller. Playing the same presets with MPE disabled and using a standard keyboard controller does not exhibit this same behavior.
Anyone else?
Thanks.
September 2, 2020 at 1:13 am #155670
Hi Natalica,
I think I just fixed an issue with this, I'm going to reach out to you about it.
Thanks,
Dan
September 2, 2020 at 4:42 am #155674
I’m running PresonusStudio One 5.0.2 in Windows 10.
MPE Controller – Sensel Morph
Pendulate works fine in standard MIDI mode but gives nothing in MPE mode.
My Morph drives other MPE VSTs just fine but not Pendulate.
September 2, 2020 at 1:16 am #155671DGillespie wrote:
Hi Natalica,
I think I just fixed an issue with this, I’m going to reach out to you about it.
Thanks,
Dan
Fantastic. Thanks.
September 2, 2020 at 3:45 pm #155679Kozmyk wrote:
I'm running PresonusStudio One 5.0.2 in Windows 10.
Is your Morph doing polyphonic pitch bend in the other VSTs? The Morph can send either MIDI or MPE and some MPE synths will receive MIDI even when their MPE mode is selected, so it's possible you're running MIDI from the Morph rather than MPE?
Dan
