Home › Forums › Products › Stompboxes › PF as Midi Master to Slave Line6 M5 Question
August 14, 2013 at 1:11 pm #111044
Gozerhead
MemberThanks to great info from the forum here, I was able to connect my PF and M5 via a midi cable (I am new to midi).
Is there a way now, to use this setup so that when I turn off the PF preset, the M5 turns on?
Currently, when I select a PF preset I can have it so the M5 is either on or off independent of the PF preset being on or off. What I want to do is this:
Have the M5 on as a tape echo (preset one of the M5 and PF). Turn on PF 1:1 (Classic Crystals) and have the M5 turn off. Then, when I turn off PF 1:1, the M5 comes back on. Right now, I have to manually manipulate the M5 to turn it off and then back on.
Thanks!!!
August 14, 2013 at 5:44 pm #124692
Imerkat
ParticipantThe only way I can see is if you get a Aux. Switch and enable MIDI Transmit CC message. M5 needs to see CC#11 to turn off/on the effect.
August 15, 2013 at 5:34 pm #124699
Gozerhead
MemberAny chance you can walk me through how to do that? Sorry, this is all foreign to me.
Doing this would let me control the M5 on/off via the Aux the, right? It would be like moving the button over?
August 19, 2013 at 1:46 pm #135540
Imerkat
ParticipantUnfortunately I don't have an Aux Switch to tested myself. You’re going to need the manual for this:
Set up Program Transmit on Preset to Send PC 00 (M5: Preset 1), Page 50 of the manual.
Hold Encoder Go to: midi -> go to XMT MAP (press) got to -> 1:1 = 00
Connect your Aux. Switch , Default is Tip- Bypass. (once you connect on of the 3 switches should bypass the effect)
Set up XMT CC (bottom page 48) to transmit CC#11 to transmit on Tip
Hold Encoder Go to: midi -> go to XMT CC (press) got to -> [TIP>C11]
Now Save the PF on Bypass position.
When you hit the Aux. Switch it will flip/flop tape delay and Crystals
I don’t know if that works but another way would be to duplicate both presets; 1:2 PF and Preset 2 on M5. If you enable transmit PC save one preset with the PF on and M5 off then the other preset vice versa.
