Home › Forums › Products › Stompboxes › Pitch and Pan Modulation on H9
October 23, 2015 at 9:12 pm #112967
I want to get pitch and pan modulation EFX on an stereo analog tape delay that I run through the parallel EFX loops of 2 amps. I have an Eclipse and 2 H9s so I’m posting same question in both forums. I suspect this is a “dumb” question that is easily addressed but I can’t figure it out. I am running the repeats only (no dry signal) thru the parallel EFX loops. I want to send them to the H9 1st for pan and slight pitch modulation but I don’t want any further delays on the repeats. Is there a way to input these repeats and get slight pitch and pan modulation w/o using a delay or obvious chorus/ flange effects? The Tape EFX don’t have much modulation and no panning EFX
Thx!
October 24, 2015 at 2:13 pm #141266
The MicroPitch, H910/H949, HarModulator, and TremoloPan algorithms immediately came to mind for slight pitch modulation and/or panning. There are some others that could fit the intent. But I think that the Vibrato algo would be the most efficient algo, using a single H9. That is, if you want the panning and pitch changes synchronized, with the potential to also sync them to the incoming delay-only signal. I would think you’d want Kill Dry ON in the system settings for the parallel loop.
An an example, this preset below is a little deep, for demontration purposes. A careful balance of INTENSITY and DEPTH will get you all the way from subtle & barely audible, to drunk & seasick. WIDTH spreads the pitch modulation from mono to stereo at the rate set in SPEED. The triangle SHAPE is smooth and linear; you might try SQUARE or RAMP for hard-snapping to delay times.
I have DEPTH MOD and SPEED MOD from 1 to 50 over the expression pedal sweep. It will fold in some RANDOM rate increases over the 1.00 Hz. SPEED. If you really want subtle (but noticeable), hit the SLOW/FAST Perfortmance Switch.
This next preset has shallower modulation, at rates closer to finger & in-fret vibrato. Again, INTENSITY and DEPTH balancing is your friend here. The VINTAGE vibe comes across as more “phase-y” (although certainly not as much as RETRO, and panning isn’t available to that). Expression pedal mapping spans the range of common vibrato SPEED. SLOW/FAST is also great for the ramping to and from the programmed SPEED. It adds variety and interest, and can disguise the periodic LFO waveforms.
October 25, 2015 at 9:40 pm #141272
Thank you! Fantastic in depth respose. I’ll give it a try tonight!
October 28, 2015 at 9:48 pm #141329
This worked beautifully. Thank You!
November 1, 2015 at 1:07 am #141388
The routing you’ve described brings up some interesting options. Many upstream effects – compressor/freeze, tremolo, deep flange, reverb, delay – add their own ‘envelope’ overlay on to your signal. The H9 modulation further downstream can use these amplitude variations to control its own effects.
It’s a modernized version of routings available in some classic rack FX [like the Lexicon Vortex preset emulation here].
This somewhat unrelated image still illustrates the basic concept: Your delay line brings a decaying envelope over your signal; chopped into discrete echoes. You can use this envelope to create changes in pitch modulation depth & rate of effect.
Primary pitch modulation uses the smoother SINE LFO. It’s sync’ed to eighth notes over MIDI, and panned wide. The secondary modulation is controlled by incoming ENVELOPE. A hefty amount of DEPTH MOD and SPEED MOD means that changes in amplitude will translate to depth & rate variations in the primary SINE wav sweep.
You can think of MOD SENS here as the maximum limit on the primary DEPTH and SPEED. Try varying the value of 35 here to increase / decrease what will happen at the input’s loudest point. The same rules apply to balance INTENSITY and DEPTH for the desired effect.
The expression pedal is set up as a sub-mixer. WIDTH is shifted from wide to narrow, and INTENSITY of effect is reduced. In my mind, it’s more accuate to look at WIDTH in terms of the phase between left & right SHAPE waveforms. A value of 99 puts them 180 degrees apart, and moving towards 0 shifts them more in-phase with each other. As an example, change the SHAPE from SINE to SQUARE, then adjust the WIDTH control. It’s easier to hear the rhythmic shuffling of modulation.
This preset is also another good candidate for SLOW/FAST performance switch variations.
My H9 is placed at the tail end of the pedalboard as a special effect toolkit. Most of my time-based effects are after the H9 in the rack / line mixer. But upstream, I do have an AdrenaLinn III, Philosopher King, EHX Freeze, PitchFactor, etc. that can feed it some effect-based envelopes. As an example, here’s a bog-standard delay preset that I route into the H9’s Vortex Reflexion preset.
Louder delays come into the Vibrato algorithm, and force faster and deeper SINE modulation sweeps. As the delays start to decay, pitch modulation becomes shallower and slower. Later repeats will ‘clean up’. While it’s not producing a true ping-pong type of delay, every other repeat will be reinforced in both L&R channels.
The only unconventional thing about the H910 / H949 preset here would be that the pitch shifter model TYPE is being swept by the expression pedal. Both FEEDBACK controls increase to maximum at the same time. PITCH is at unison, so TYPE shifting will only inject some glitchy artifacts into the decaying repeats. It breaks up the echo loop in interesting ways (to me, anyway).
November 4, 2015 at 5:20 pm #141442
Great stuff! Thanks!
