Is there anybody out here who can tell me if it is possible to conect an external switch pedal to the Pitch Factor Aux Switch to get a MOMENTARY active /by-pass function, and what external pedal should that be? I tried to do this with a Boss FS-5U but the Pitch Factor doesn´t seem to recognize it. I would really appreciate any input
You can't do it with a regular switch (this only toggles the bypass state), but you can by using a MIDI controller, which will allow you to control Bypass On (BYP) Bypass Off (ACT) or Bypass Toggle (TOG).
