Home › Forums › Products › Stompboxes › pitch factor problem
[View:http://youtu.be/lDMfkUqlfAc:550:0%5D
hello!
i have this problem (video above) in my pitch factor stomp box, does anyone know this problem? what to do?
thank you very much!
Nimrod.
You should send a link to this video and a good description of what's happening to support@eventide.com.
Mine does the same thing from time to time. Did they ever give you a response to why it was doing that?
Link was in the original post.
Mine has never done that. Disco light feature?
It's almost certainly a bad internal connection to the display board. If it is under warranty, contact support@eventide.com. If not, find a good local tech, and have him check the connection to the top board.
