Pitch Mix in Shimmer Reverb
Home Forums Products Stompboxes Pitch Mix in Shimmer Reverb
    • #185997
      GrimyRen
        Hi all
        I got my H90 for about a week now. I am baffled what you can do with the unit but i got a question. Is there a way you can change the Mix of the Pitch A and B in the Shimmerverb relative to each other? For instance i want more of pitch A and just a bit of pitch B.
        Thanks in advance
      • #185998
        Sawite
        • #186003
            … Is there a way you can change the Mix of the Pitch A and B in the Shimmerverb relative to each other?…
            I meant to try this out (but did not):  Use Low Band Decay & High Band Decay as your ‘pitch mixer’, and Pitch Decay as the master level of total pitch shifting.
            I think the success of this will depend on the intervallic distance between Pitch A & Pitch B.  Opposing octaves may be easier to dial in.  Upward shifts with P4ths & P5ths might be difficult.  Any significant amount of Delay time could smear everything back together when it’s recycled.
            https://cdn.eventideaudio.com/manuals/h90/1.1.2/content/algorithms/reverb.html#shimmer
            Best I got for you.
