Pitch shifting
Home Forums Products Rackmount Pitch shifting
Viewing 3 reply threads
    • #105376
      Am I correct in assuming the Eclipse is incapable of formant correct pitch shifting?
    • #117004
         For technical reasons the Ultrashifter is not available on Eclipse.
         It is available on H7600 and the H8000 family.
      • #117157
        What is formant correct pitch shifting?
      • #117160
         From Wikipedia:
        Formants are the distinguishing or meaningful frequency components of human speech and of singing. By definition, the information that humans require to distinguish between vowels can be represented purely quantitatively by the frequency content of the vowel sounds. Formants are the characteristic partials that identify vowels to the listener.
        http://en.wikipedia.org/wiki/Formants
        Traditional pitch shifting doesn't calculate formants so, as a basic rule, as soon as you shift a sound more that +/- 1/3rd from its fundamental frequency you start getting artifacts in terms of non_resemblance with he original sound. The more you shift the more artifacts you'll get….up to chipmunks and godzilla sounds.
        Formant correct shifting is a very heavy process in which pitch AND formants are re_calculated to keep a higher level of fidelity with the original sound at any shift setting.
        all the best
