Pitchfactor 240v -110v question
Home Forums Products Stompboxes Pitchfactor 240v -110v question
    • #107266
      radioghost
      Hi all
      I have a Pitchfactor and currently run it with the supplied 240v power supply.  I will soon need to use it on 110v (US) power.
      I assume I can just buy a 110v (9VDC 1200mA)  adapter and use it normally?  ie I don't need to use a step-up transformer with my existing 240v adaptor..
      If this is the case, do most stores that carry Eventide products stock these adaptors or would I have to order one from Eventide?
      btw – Great pedal. have only just started scratching the surface of what it's capable of..
      thanks,
      RG
    • #120745
      You can buy a range of international power supplies from the Eventide store.
    • #120777
      badmelonfarmer
      if you want an easy to pick up option you can use a onespot with a L6 adapter.
      be warned though, you can not daisy chain the power on Factor boxes, they get really noisy..
      Cheers
      BMF
