PITCHFACTOR AUX SWITH PEDAL?
Home Forums Products Stompboxes PITCHFACTOR AUX SWITH PEDAL?
Viewing 4 reply threads
    • #107132
      BLooDRuST
      I know the manual says you must use a stereo momentary, so any stereo momentary will work? I just don't want to run into the potential issues I notice that regard the Expression pedals… Thanks.
    • #120505
      Not quite sure to what you are referring. Assuming you mean the AUX Switch, this requires a stereo connection (meaning Tip/Ring/Sleeve), but not a stereo switch. It can accept one or two or three momentary switches with appropriate wiring. We use Digitech FS300.
    • #120509
      BLooDRuST
      Cool pedal. So I can assign one of those buttons for the tuner and I won't have to hit it twice? Then the next button could be for bypass, etc., – whatever I assign it to, right? Thanks for the fast replies!
    • #131723
      Correct. Check the User Manual to see the options.
    • #120595
      hywelg
      TC G-Switch also works.
