Home › Forums › Products › Stompboxes › PitchFactor Bellamy’s Harpeggiator
- This topic has 2 replies, 1 voice, and was last updated 2 months, 3 weeks ago by
brock.
May 9, 2013 at 11:28 am #110929
Hello everybody i'm new to this forum! i have the pitchfactor in front of my marshall jvm and timefactor and modfactor in send/return! I found these pedals absolutely amazing but.. here's the question..
I play in a cover band and we do also Muse.. I'm looking for how to achieve Bellamy's sound in "map of the problematique" with my pedals.. There's something similar to, but want the harpeggiator working like this
Any idea? Thank for your support and sorry if my english isn't perfetc, I'm from Italy 🙂
BYE!!
May 11, 2013 at 1:11 am #124483Quote:… how to achieve Bellamy's sound in "map of the problematique" with my pedals.. There's something similar to, but want the harpeggiator working like this …
I wish that I had better news here. There are only a limited number [26 plus random] of fixed pitch patterns in the HarPeggiator. None of them are what you're looking for. I've come up with an interesting preset or two in the HarPeggiator that comes fairly close to this song, but it's not the same feel or pattern found in Muse – 'MotP'.
Here's the 16-step pitch sequence that you'd need in the Harpeggiator. To reproduce this exactly, you'll have to have an external sequencer of some kind, and use another PitchFactor algorithm to pull this off. The HarModulator or H910/H949 would be good choices (anything with +/- 1 octave and unison).
But I used the Diatonic / Quadravox MIDI CC values here. The default MIDI CC numbers (in the global System settings) would be CC34 – Pitch A and CC35 – Pitch B. Of course, the PitchFactor will have to be set up to receive MIDI messages, on the proper MIDI Channel.
Map of The Problematique Pitch Sequence (Diatonic or Quadravox)
01] -1 oct (CC Value 33)
02] unison (CC Value 64)
03] +1 oct (CC Value 94)
04] unison (CC Value 64)
05] +1 oct (CC Value 94)
06] unison (CC Value 64)
07] -1 oct (CC Value 33)
08] unison (CC Value 64)
09] +1 oct (CC Value 94)
10] unison (CC Value 64)
11] +1 oct (CC Value 94)
12] unison (CC Value 64)
13] -1 oct (CC Value 33)
14] unison (CC Value 64)
15] +1 oct (CC Value 94)
16] unison (CC Value 64)
Note: Each of the PitchFactor algorithms scale their parameters differently, with regards to control via MIDI CC values. Those listed above apply to the Diatonic & Quadravox modes. The MIDI CC values for controlling Pitch A & Pitch B would not be the same for HarModulator, H910/H949, etc. Each algorithm has its own unique number of parameter positions; yet all are scaled over the same 0-127 CC value range.
January 27, 2025 at 1:59 pm #187925
Necro update, only 12 years in the making.
- For the SIFT algorithms, Polyphony & PolyFlex.
- Requires an external sequencer (Morningstar, etc.), capable of MIDI CC transmission.
- Match MIDI Channels for the sequencer and the H90.
- Select one (or two) MIDI CC numbers to the sequencer output.
- Enter the CC values below into a 16-step sequence.
- Map Shift A and/or Shift B to the same (one or two) MIDI CC numbers.
