Pitchfactor Bug report
Home Forums Products Stompboxes Pitchfactor Bug report
Viewing 5 reply threads
    • #111562
      Imerkat
      I'm having problems with the quadravox algorithm after the update. it's not saving the key or scale but only when I load it with MIDI PC. I want to save it in F# Maj but it pulls up as C Maj.
    • #125779
      gkellum
      Thanks for the feedback. We'll look into it.
    • #125780
      gkellum
      imerkat:
      Ok, we're having trouble reproducing this. Did you save the change directly on the PitchFactor or did you save it to the PitchFactor using H9 Control?  And when you say "only when I load it with MIDI PC", you mean that you only see the problem when the saved preset is loaded via MIDI program change messages but not when the preset is loaded using the footswitches?
    • #125791
      Imerkat
      Yes. I built the preset in the H9 Control and recalled it with a midi control but I saved the key manual after. it saves the right key until I turn it off and power it up again. is there a way to initialize the preset so I can start from scratch and see if that fixes it?
      PS- One thing I notice, this weekend at a gig, is that if I'm pulling up a preset in the same algorithm there is a lot less gap between sound if at all. which is very cool!
    • #125876
      h9controller
      Hi imerkat.  I was checking into this issue and just wanted some more info.
      Can you attach a screen shot of your H9 Control settings for this Preset, before you manually save the key?
      As well, when the Pitchfactor changes keys, are you hearing that's it's changing to C or is it just the Pitchfactor's display that changes (or both).
    • #125896
      Imerkat
      I "found" some time to show you guys. Repeated this process twice
      [View:http://youtu.be/SaqeFddSLLU:550:0%5D
