Pitchfactor: can’t get past bank 13:2
Home Forums Products Stompboxes Pitchfactor: can’t get past bank 13:2
    • #106667
      RolloTomasi
      Every time I try t go past bank 13:2, I end up back at bank 1. How do you acess any banks higher than 13?
      Thanks for any help!
    • #119545
      jhyman
      You need to go into System Mode by pressing and holding down the Encoder and Right Footswitch button together. Then turn the Encoder to UTILITY, select it by pressing it down, turn it to BANKS and select it, and then set the range of the banks you want to use. Yours is probably set to an upper limit of 13.
    • #119556
      RolloTomasi
      Awesome – thanks so much for the help!
