pitchfactor changes settings by itself
Home Forums Products Stompboxes pitchfactor changes settings by itself
    • #107786
      I have an 25k vp jr expression pedal plugged into my pitchfactor and the settings change themselves.  I tried resetting the unit and I turned catchup on.  I also tried a different expression pedal.  anything else i could try?  Thanks!
    • #121897
        Try a different cable, especially a mono one ( tip,sleeve but no ring). Also try pushing the jack in and out of the sockets at each end a few times to clean the contacts.
        One of the above will probably fix it, otherwise support@eventide.com
