Pitchfactor Expression Pedal Values Jump
Home Forums Products Stompboxes Pitchfactor Expression Pedal Values Jump
Viewing 3 reply threads
    • #106973
      My PF parameters values jump up and down when that parameter is controlled by expression pedal automatically without touching the expression pedal.  Parameters make jumps up and down about 2 to 3 value numbers.  I have tried an Ernie Ball Jr. 25k, a Roland EV5, and a Rogue volume pedal.  I have even swapped out cables when trying to use either of the volume pedals.  The pedals I have work fine with MF and TF.  This is really a problem when expression pedal is controlling intervals, it can go from -m2nd to -m3rd on it’s on.  The other strange thing is that it is not constant, it does it for a while stops for a while and starts again.
      Any ideas, bug? or pedal needs repair?
      Thanks,
      A
    • #120189
      Maybe a bad contact at the jack – try pulling it in and out 10 times, with a bit of switch cleaner on the plug if you can find some.
      If this doesn't fix it, it probably needs to be looked at.
    • #120203
      Where would I send the PF to be looked at,……..is it covered under warranty?
      A
    • #131368
      The warranty info is on the last page of the User Manual. Since PF is quite a recent product, most units are still covered.
      If you are sure the unit is broken, contact your dealer or support@eventide.com
