Home › Forums › Products › Stompboxes › Pitchfactor Expression pedals too sensitive
September 24, 2019 at 3:10 pm #115526KentuckyThrashMember
I have the pitchfactor, and notice that the sweep with both an Ernie Ball VPJR 25K (with a linear pot, I replaced it), and a mission engineering Areo EP-25 Pro, both have the same uneven sweep.
The pedal is probably engaged only 15% but the pitchfactor is interpreting that as at value 50 of 100.
I’ve tried calibrating the pedals. The toe position does end at 100, and the heel position is at 0, but the value jumps to 80% only engaging the pedals around 20%. Is there any solution to this problem?
September 24, 2019 at 3:14 pm #152756
Does sound like you still have a log pot. Would be helpful to have someone check it with a DVM.
September 25, 2019 at 4:38 pm #152772camnParticipant
A Multimeter.
You should confirm they are linear.. though the EP-25 ships with a linear taper… so it would be unusual.
What pot did you use in the Ernie Ball? Also a 25k? I know the H9 supports up to 25k.. but maybe try a 10k?
September 26, 2019 at 12:52 am #152776KentuckyThrashMember
They’re both 25K linear pedals. I am going to try a 10K pedal. I hope that’s what will do the trick. I ordered a Mission Engineering EP-1. It’s 10K linear, and I have a Helix so it will at least work with that I hope.
October 4, 2019 at 7:08 pm #152840KentuckyThrashMember
I got a 10K linear pedal and tried it. Still too sensitive, and also will not calibrate past the value of “87”. This is the 4th pedal I’ve tried with the PitchFactor. Can anybody verify a pedal they’ve gotten to reliably work with the pitchfactor to use the Pitchflex effect?
October 5, 2019 at 12:41 am #152842camnParticipant
Yeah that sounds wack.
I use a Mission. SP-H9 without issue. -
October 5, 2019 at 2:20 pm #152848camnParticipant
Ha ha with the H9. With the Pitchfactor ALGO.
I had been reading this the whole time as an H9 issue, cuz that algo has some expression pedal tracking problems sometimes.
Sorry man. I don’t even have a Pitchfactor. 🙂
February 11, 2020 at 5:50 pm #154044KentuckyThrashMember
I decided to give it one more try with a Mission Engineering EV pedal (specifically made for the pitchfactor). I have the exact same problem. This is the 6th pedal I’ve tried. Can I send the pitchfactor to Eventide and have them attempt to resolve the issue that way? I’d really like for this to work and don’t want to sell it to somebody else knowing that expression pedals don’t work right with it.
February 11, 2020 at 7:59 pm #154045camnParticipant
Maybe it would be worth a trip to a guitar stóre to try the exp with a different Pitchfactor pedal?
February 12, 2020 at 5:09 pm #154052KentuckyThrashMember
I’m considering getting this as a solution:
If I can select the kind of taper and whether it’s a passive or CV signal, there’s got to be a combination that will work, and it takes the pedal out of the equation. Anybody have experience with such a thing?
February 18, 2020 at 10:19 pm #154110KentuckyThrashMember
Well, I got the expressionator, and it shows me exactly what position the pedal is in. While the level displays on the expressionator as evenly rising relative to pedal position, the PitchFactor STILL does the same thing. The Expressionator shows 20% and the PitchFactor shows 60%. Switching back and forth between log and linear shows me that the PitchFactor is even more sensitive in log mode.
I’ve jumped through every hoop there is to jump through. This is a problem with PitchFactor unit itself. How can I get this repaired?
The problem is that it’s 2 different pedals that do the exact same thing :/
Check what? And what is a DVM?
September 25, 2019 at 6:10 pm #152773Herr MosaParticipantKentuckyThrash wrote:nickrose wrote:
…if it’s log or lin – use a Multimeter (DVM) that can determine resistance values…
October 5, 2019 at 1:37 am #152845KentuckyThrashMembercamn wrote:Yeah that sounds wack. I use a Mission. SP-H9 without issue.
You use the SP-H9 with the Pitchfactor or the H9?
February 11, 2020 at 8:03 pm #154046KentuckyThrash wrote:
I decided to give it one more try with a Mission Engineering EV pedal (specifically made for the pitchfactor). I have the exact same problem. This is the 6th pedal I've tried. Can I send the pitchfactor to Eventide and have them attempt to resolve the issue that way? I'd really like for this to work and don't want to sell it to somebody else knowing that expression pedals don't work right with it.
Have you tried calibrating the expression pedal setting on your H9 (or in H9 Control)?
February 11, 2020 at 8:26 pm #154047KentuckyThrashMembercamn wrote:Maybe it would be worth a trip to a guitar stóre to try the exp with a different Pitchfactor pedal?
I looked online and no local stores carry the PitchFactor.
February 11, 2020 at 8:31 pm #154048KentuckyThrashMemberbohan wrote:KentuckyThrash wrote:
Yes, although I have a PitchFactor, not the H9.Here’s what I’ve tried:– calibration (turning auto calibration off and on)– plugging in the expression cable first, then power.– updating the firmware.– Different types of cables (stereo vs mono)– 6 different expression pedals, 5 were 25K, one was 10K -
I've jumped through every hoop there is to jump through. This is a problem with PitchFactor unit itself. How can I get this repaired?
Thank you for all your feedback. We looked into this issue. We think this is a fault in the schematic design. So it is PitchFactor's problem, but not particular to yours.
H9 is different and doesn't have this problem. We think a 5k pot may work better with PitchFactor, but we cannot promise how much better it gets.
