PitchFactor: Fine tuning of delay times in V3b not happening?
Home Forums Products Stompboxes PitchFactor: Fine tuning of delay times in V3b not happening?
Viewing 4 reply threads
    • #107568
      Burger666
      Is it just me or are others having this issue as well? I can't fine tune delay times with the encoder as per the original instructions. I'm guessing (and hoping) it's a bug in the V3 beta.
      Anyone else?
      Thanks.
      Brett K.
    • #121418
      Just checked and yes I have the same problem on my PF.
    • #121456
      I wanted to verify having the same V3 beta results here (in case this thread ends up 'lost in Space').  It appears that the 2 second 'timeout' is still active; but the delay time doesn't react to encoder movement.  After the two second period has passed, the encoder changes the PF algorithm (as it always has).
    • #121464
      Hi Brett
      You were trying to use the fibonacci numbers, weren't you? I tried the same and it doesn't take 377 and also 610 it just gets close to. I can't actually tell if this was a problem before the update because I was using the tap tempo only. I noticed that if I use the tap tempo it does give me some numbers that i wouldn't get if I were manually dialing them in.
      David
    • #121465
      Burger666
      Davide Schachter:
      Hi Brett
      David
      Spot on, David. It must be a bug and I have no doubt that our algorithmic benefactors are working on a fix right now. 🙂
