Pitchfactor H910 emulation
Home Forums Products Stompboxes Pitchfactor H910 emulation
Viewing 7 reply threads
    • #111218
      deep88
        why is running with a low pass filter and no chance to set or turn it off?
      • #125039
        Imerkat
          not sure what you mean, do you think the effect is too dark? I haven't notice a filtering effect on the Wet or Dry signal
        • #125041
          deep88
            well not in the dry segnal, but in the wet one…. does your unit have the same tone in both wet and dry?
            dry on mine is completely clear so, total dry, but wet sounds so lofi
            can u check ur?
          • #135837
            Imerkat
              I'm still confuse. I have heard some people complain their dry tone sounds suffers when the effected wet signal mix in. Or do you mean the wet signal itself sounds lofi?
            • #135838
              deep88
                so make this experiment
                send a loop so u can recognize the differences
                set it to completely dry…. perfect sound
                now set it to 0 delay, 0 feedback, 1.00 pitch and totally wet…. can u hear the lofi sound?
              • #135839
                  Yes.  That's the H910 'character' you're hearing.  It was an amazing piece of hardware for its time (mid-70's).  Analog delay chips were noise buckets back then, and one solution was to lower the bandwidth.  Longer delay times meant that the "low pass filtering" cutoff frequency was reduced.  Usually, you'd get a range of delay times; each with its own bandwidth. I believe that the H910 was a 16-bit/ 15kHz machine overall.
                  Part of the lo-fi charm of the H910 and H949 algorithms is the varying degree of glitching, deglitching, and warblyness found in each variation,  In your experiment –  if you move the Depth / Key knob to MODERN at 1.000 –  you'll hear clean, subtle unison doubling.  That sounds like what you're looking for.
                  But don't overlook the unique, useful sounds in the H900 series.  You can really start to hear the differences between the 3 hardware emulations and digitally-clean when there is some pitch shifting involved.  You can set up up a simple preset, and sweep the Depth / Key knob to compare one with the next:
                  TidesOfHistory
                  Mix = WET:50
                  Pitch Mix = A10+B10
                  Pitch A = A: 1.498
                  Pitch B = B: 2.000
                  Delay A = 0 ms.
                  Delay B = 0 ms.
                  (encoder) = 910/949/ TMP OFF
                  Depth / Key = H910 / H949-1 / H949-2 / MODERN
                  Speed / Scale = CHROMTC
                  Xnob = FBK-A:  0
                  Ynob = FBK-B:  0
                • #135840
                  deep88
                    brock:
                    thanks to get into the post mate 🙂
                    well this is what i was thinking too… before try a real h910… it doesn't sound so lo fi, that why i'm here asking this
                    no i try and the MODERN setting is just for deglitching… no impact on the tone… u can make my test (as before 0 delay, 0 feedback, 1.00 pitch, 100wet) and try to switch the different algorithm… nothing change (u can notice the different settings just as u say below on long delay feedback, where u can hear glitch from 910 to 949 (without and with the deglitching board) to Modern no glitch
                  • #145613
                    deep88
                      wondering if we have some news on controlling the filter cutoff (maybe with midi)
