Home › Forums › Products › Stompboxes › Pitchfactor help
December 6, 2016 at 6:00 pm #113859
I have a few questions. I run my wdw rig as such guitar- wah – 5150 – Weber mass-internal speakers – line out from mass- pitch factor (split output) – rotosphere a/b input – a/b outputs from rotosphere – carver mosfet 450- l/r 2×12 speaker cabs
My questions are
1.setting it so when the pitchfactor is off and all signals are dry from all speakers, getting the volume to be the same as when the pitchfactor is on2. Getting the same sound out of the wet cabs as the dry speakers being as the Weber has an eq for the line out
3. Saving the wet level for each preset to be individualized to each preset
4. General settings for bypass, input level, and any great tips or tricks for the set up I’m running
5. How to use the flex system for presets while in bank mode
6.going down in banks, for instance,from bank 5 to bank 4, instead of only being able to go up in banks
7. Delay settings that don’t get overbearing but are still prominent
I know it’s alot to ask but I’m new to the pitchfactor and could use as much help as I can with it I know there’s alot to it even with the system settings so any help with those would be great as well. I play everything from jazz country blues rock metal and classical. I use the pitchfactor for a wide variety of things. Mostly pitch shifting and delays but also the oddball stuff. I know my gear very well apart from this piece and I’m still learning alot everyday about this new rig but I can do just about anything I need to to my own equipment. I’m mostly just looking for answers to my questions and tips, tricks and best kept secrets. -
December 6, 2016 at 8:49 pm #145047
This is always tricky as different presets have different levels anyhow, and will be further modified by the characteristics of your guitar. The best bet is to adjust the preset output gain on a preset by preset basis for those presets which have seriously different output levels.
Not my knowledge area.
Make sure GLOBAL MIX is off – then the wet/dry mix will be saved with each preset.
4. General settings for bypass, input level, and any great tips or tricks for the set up I'm running
This is for you to try, as only you know what you want.
Don't understand. Flex ?
To go down in banks you have to use MIDI or an AUX SWITCH.
7. Delay settings that don't get overbearing but are still prominent
A three button Aux. Switch will solve both problems. I use the Digitech FS300 which is the precursor to the FS3X. http://www.sweetwater.com/store/detail/FS3X
Any three button momentary latching footswitch with a TRS cable will work.
