PitchFactor: Out of phase issue on Octaver and HarPeggiator
Home Forums Products Stompboxes PitchFactor: Out of phase issue on Octaver and HarPeggiator
    • #112424
      Jenzz
      Hi .-)
      The 'random' Out of Phase issues on the Octaver (both pitch A and B) and constant out of Phase HarPeggiator (only pitch B) are well known for a while, but Evenbtide didn't come up with a solution so far… Is there any hope on a fix on this? Or is it a hardware / sync processors issue? I love the Pedal, but these tech issues bother me… I have tested 4 Pitchfactors now (newest and older firmware versions) and all exhibit these issues…
      regards, Jenzz
    • #127651
      I've never been able to track down the dropout issues that I've had with the HarPeggiator fuzz.  I chalked it up to some phase flip in the pedalboard that I may have missed.
      Now that I've Max'ed out an H9, I thought that I might be able to 'flip it back' with 2 HarPeggiators in series [PitchFactor + H9].  Not much luck with the fuzz dropouts so far (but some incredible results with random filters in series).
      I'm still looking for a recipe to nail it all down.  I haven't experienced the Octaver issues that you mentioned, but that algo gets more limited use here.
    • #138751
      Jenzz
      Hi .-)
      The mentioned Octaver issue only occurs if you run the Pitchfactor with stereo Input (both sockets connected). If you connect the input mono, the out-of-Phase issue on the Octaver will not occur. Only the 'Pitch B' HarPeggiator is out-of-Phase, 'Pitch A' is allways in-Phase.
      Jenzz
