Has anyone else had the problem of their pitchfactor pedal taking a long time to power on? I’ve updated the software, did a factory reset and even tried different power supply. For example, if let’s say I don’t play for a day or so it takes 5-10 minutes for the pedal to power on. Once it powers up, if I turn it off and on again it powers up instantly. When the pedal is on, there’s no issues whatsoever. Very strange. Thanks in advance.
It just sits blank. It’s the strangest thing. When I power on, every other pedal works except the pitchfactor. Once it powers on, it works as it should. I have the factory power supply and yes it works fine. I even have other pedals that fit it and they power right on using it, eliminating the problem being the supply. I think I have a finicky pedal to be honest haha. If that’s the only problem, I can deal with it. It’s just very odd.
