Home › Forums › Products › Stompboxes › Pitchfactor (PF07919) the Picth A button doesnt work
May 27, 2021 at 5:35 pm #116518TwandaMember
Hello there,
My Pitchfactor (PF07919) as a problem: on most of the presets, the A ‘channel’ from the Picth A button doesnt work: I only have 2 voices on the Quadraovox, only one apregioator on the B button, one voice one the Picthflex etc..
If I turn the Picth Mix button right, I hear voices BD, but if I turn it left i hear nothing (besides some dry if MIX isn’t fully wet).
Of course, the PicthMix button works properly, as i see and I hear a difference when I turn it. But they is nothing coming out from the ‘A’ channel anymore..
Only the Octaver and Synthonizer ar working properly. this is anoying.
Any Idea ?
So I did an update of my software through the Eventide Direcft Updater, but no difference. As wella sI few ‘restes’
thank you
Toine from Brussels
May 27, 2021 at 10:37 pm #157959Twanda wrote:
Hello there,
My Pitchfactor (PF07919) as a problem: on most of the presets, the A 'channel' from the Picth A button doesnt work: I only have 2 voices on the Quadraovox, only one apregioator on the B button, one voice one the Picthflex etc..
If I turn the Picth Mix button right, I hear voices BD, but if I turn it left i hear nothing (besides some dry if MIX isn't fully wet).
Of course, the PicthMix button works properly, as i see and I hear a difference when I turn it. But they is nothing coming out from the 'A' channel anymore..
Any Idea ?
So I did an update of my software through the Eventide Direcft Updater, but no difference. As wella sI few 'restes'
thank you
Toine from Brussels
What's your setup? Mono in mono out? Mono in stero out? Or stereo in stereo out? Do you use any special routing mode (pre/post, dry/wet)?
June 5, 2021 at 10:06 am #158030TwandaMember
Hello there,
thank you for your quick answer (sorry for beeing so slow, i had .. actual live concerts !)
I come in and go out in Mono, this is with 1 jack in, AND 1 jack out.
But it always has been like since 5 years, and suddenly know I loose the A-channel (on some preset only: Only the Octaver and Synthonizer are working properly).
I do not use any special routing, as my pedal is set on ‘normal’ (see attachent).
June 7, 2021 at 6:54 pm #158044
You can try reinstalling the lastest software, and a factory reset after that.
Do all Delay algorithms work in stereo?
June 9, 2021 at 10:08 am #158053TwandaMember
Hello there,
I tried reinstalling, and it seems to work this time ! Oncredible, i spent so many ours on this
thank you all
