Pitchfactor power adaptor
Home Forums Products Stompboxes Pitchfactor power adaptor
    • #141271
        You don't say if your measurement was under load, or not. This makes a difference.
        But, either way, the PF can handle 12V. (But, don't give it much more).
      • #112973
        Hi all,
        I have a Pitchfactor that I use on a daily basis. Yesterday I checked the voltage coming out of the power adaptor (an original one) and apparently is feeding almost 12V instead of 9V. Is that normal? I have used it for quite a while and never reported problems, but truth to be told now I am a bit worried. I also tried another one (not original) set at 9V and the pedal works ok.
        Cheers,
        Antonio
