Home › Forums › Products › Stompboxes › PitchFactor Preset Programming: “Other” Effects
- This topic has 40 replies, 3 voices, and was last updated 3 years, 5 months ago by
AndrewM.
January 2, 2013 at 3:35 pm #109443
The PitchFactor is capable of any number of effects that don't have a primary focus on pitch shifting. Most work well summed to mono, with a stereo routing sounding more distinct and differentiated. The Harpeggiator mode is one rich source of these effects. Here is one of my favorites:
RandomFilters
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = ArpA: OFF
Pitch B = ArpB: OFF
Delay A = GrvA: OFF
Delay B = GrvB: OFF
(encoder) = PEGGIATOR / TMP ON
Depth / Key = ATK: 3
Speed / Scale = LN: 1/16
Xnob = FXA: RnFL
Ynob = FXB: RnFL
(EXP PED Heel) = GrvA: OFF GrvB: OFF
(EXP PED Toe) = A01 B01
Classic "sample & hold" filter effect. The clocked random filter patterns from A & B combine for a more random feel in a 1/16th note progression. Works well with clean-to-distorted input, single notes, chords, and arpeggios. Can benefit from a strong, sustained signal.
Expression Pedal:
Each of the sixteen steps are played at full amplitude with the groove patterns disabled. Past halfway on an expression pedal brings an emphasis on each step's attack with the groove :01 patterns and the Depth / Key value of ATK: 3.
Quick Variations:
Mix = Reduce 100% WET for more subtle filtering.
Delay A; Delay B = A pallette of rhythmic variations.
Depth / Key = Sweeping filters to filter blips.
Speed / Scale = Rate changes from barely noticeable to gargling filters.
January 2, 2013 at 4:26 pm #124141
SquareTremolo
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = ArpA: OFF
Pitch B = ArpB: OFF
Delay A = GrvA: A07
Delay B = GrvB: B07
Depth / Key = ATK: 0
Speed / Scale = LN: 1/32
Xnob = FXA: OFF
Ynob = FXB: OFF
(EXP PED Heel) = LN: 1/16
(EXP PED Toe) = LN: 1/64
Sharp-edged tremolo effect that instantly varys between silent and full amplitude. Uses Delay A + Delay B groove pattern :07 to create the effect.
Expression Pedal:
Because of the groove pattern construction, the effect rate is slower than expected. Use the expression pedal for slower and faster rates that remain sync'ed to tempo.
January 2, 2013 at 4:48 pm #124142
StereoSlicers
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = ArpA: OFF
Pitch B = ArpB: OFF
Delay A = GrvA: A12
Delay B = GrvB: B10
Xnob = FXA: OFF
Ynob = FXB: OFF
(EXP PED Heel) = ATK: 0 FXA: OFF FXB: OFF
(EXP PED Toe) = ATK: 10 FXA: FLT 1 FXB: FLT2
Two groove patterns combine rhythms for a single slicing effect. Find two patterns for Delay A and Delay B that compliment each other. Sparse rhythms leave room for a 2nd pattern. Most slicer effects become more distinct with Mix = 100% WET.
Expression Pedal:
The envelope attack over each step increases from full amplitude to 1/10th of the step duration. Two different filter patterns are gradually blended in from the effects section. Individual slices become more staccato and frequency-dependent at the toe position.
January 2, 2013 at 6:48 pm #124143
SpinSweeper
Mix = WET:100
Pitch Mix = A7+B10
Pitch A = ArpA: OFF
Pitch B = ArpB: OFF
Delay A = GrvA: A03
Delay B = GrvB: B04
(encoder) = PEGGIATR / TMP OFF
Depth / Key = ATK: -5
Speed / Scale = LN: 250 ms.
Xnob = FXA: OFF
Ynob = FXB: OFF
(EXP PED Heel) = LN: 250 ms.
(EXP PED Toe) = LN: 50 ms.
Stereo panning effects. In a mono application, it's closer to a looped attack delay effect. Two offset groove patterns alternate active step positions. Pitch Mix attempts to correct for the maximum level difference in the Delay B pattern. The slow attack setting for Depth / Key sweeps the patterns left to right (and back again).
Expression Pedal:
The heel position resets to the default cycle rate [250 milliseconds). The toe position ramps up the speed to the 50 ms. top limit. This can be useful in emulating a Rhodes or Leslie effect (in conjunction with the rest of your pedalboard).
January 2, 2013 at 7:05 pm #124144
SplicerGlitch
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = ArpA: OFF
Pitch B = ArpB: OFF
Delay A = GrvA: A05
Delay B = GrvB: B12
(encoder) = PEGGIATR / TMP ON
Xnob = FXA: GLT2
Ynob = FXB: GLT1
(EXP PED Heel) = ATK: 5
(EXP PED Toe) = ATK: -5
Two steady groove patterns add glitching accents to create a more complex rhythmic effect. Interaction among the five glitch patterns, the 20 groove patterns, separate A & B channels, and the Depth / Key attack control varies the effect from barely noticeable to an overwhelming glitch-fest.
Expression Pedal:
Backing off the pedal brings the glitches to the forefront, with pushing forward smears the groove patterns and glitch steps together.
February 4, 2013 at 4:56 pm #135196
Time to drop another batch of presets. Along with the rest of the entries above, these are basic configurations meant to be tweaked and customized.
AttackTremolo
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = ArpA: OFF
Pitch B = ArpB: OFF
Delay A = GrvA: A06
Delay B = GrvB: B06
Depth / Key = ATK: 5
Speed / Scale = LN: 1/8
Xnob = FXA: OFF
Ynob = FXB: OFF
(EXP PED Toe) = ATK: 0
This patch emulates a sawtooth-like LFO controlling amplitude, for a different kind of tremolo effect. It can also be used as a steady slicer at different rates, or a fake delay effect (using the guitar's natural decay). It has a sharper ramp characteristic on the groove "slices" than the usual sine- or square-wave LFO on many tremolo units.
Expression Pedal:
Pushing the expression pedal towards the toe position fades out the sharp attacks, and becomes a subtle pulsing that's barely audble. Use it actively to vary the solid pattern emphasis.
February 4, 2013 at 5:17 pm #135197
EdgeDelays
Mix = WET:50
Pitch Mix = A10+B10
Pitch A = 1:000
Pitch B = 1.000
Delay A = 1/4
Delay B = 1/8*
(encoder) = 910/949 / TMP ON
Depth / Key = MODERN
Speed / Scale = CHROMTC
Xnob = FBKA: 0
Ynob = FBKB: 0
(EXP PED Heel) = FBKA: 0 FBKB: 0
(EXP PED Toe) = FBKA: 100 FBKB: 100
The PitchFactor functions as a great primary or secondary digital delay unit. This preset exploits the dotted eighth rhythmic effects. By changing Depth / Key to one of the H910 or H949 variations, it's possible to emulate one of the earlier bucket-brigade digital delays.
Expression Pedal:
Not all delay units will allow infinite feedback. Although this preset can go into short-delay looper territory, the expression pedal is set up for active use here. The heel position snaps back to one repeat from each delay line. The toe position goes into total regeneration. By moving the pedal to many intermediate positions, the short delays are perceived as additional notes played, or rapid arpeggios & finger-picking.
February 4, 2013 at 5:39 pm #135198
VibratoWhammy
Mix = WET:50
Pitch Mix = A10+B0
Pitch A = 50c
Pitch B = -50c
Delay A = 0 ms.
Delay B = 0 ms.
(encoder) = MICRO / TMP OFF
Depth / Key = DPTH: 100
Speed / Scale = SPD: 80
Xnob = FBK: 0
Ynob = FLT: 0
(EXP PED Heel) = WET: 0
(EXP PED Toe) = WET: 100
Wide vibrato or whammy bar effects are available in this preset. Speed / Scale is set for a moderately-fast, "natural" rate. Increase or decrease that by 10% or so for faster & slower "natural" effects. Vary the speed much more to dive into "electronic" rates. Pitch Mix is shifted to the left for a "bend up" quarter-tone vibrato. Change that to A0+B10 for "bend down", or to A10+B10 for both directions simultaneously.
Expression Pedal:
The pedal is set up to fade in vibrato effects from no vibrato, through an equal blend, and landing on total pitchbending. A rapid move through the pedal range will emulate near-instant vibrato.
February 4, 2013 at 5:56 pm #135199
RotoGrinder
Mix = WET:85
Pitch Mix = A10+B10
Pitch A = A:01
Pitch B = OFF
Delay A = GrvA: A03
Delay B = GrvB: B20
Speed / Scale = LN: 22 ms.
Xnob = FXA: OFF
Ynob = FXB: OFF
(EXP PED Heel) = LN: 50 ms.
(EXP PED Toe) = LN: 10 ms.
Minimal pitch shift is used here to accent the cyclical machine sound. This is an unusual effect that may be useful in more limited applications. It has an electronic type of overlay with an emphasis on grinding, non-tempo sync'ed rates. Complexity is added by allowing a small amount of the dry signal to leak through.
Expression Pedal:
Control over simple rate changes from relatively slow to maximum speed. Change the Heel setting to 250 ms. to bring the machine to a grinding halt.
February 4, 2013 at 6:26 pm #135200
RandomChops
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = OFF
Pitch B = OFF
Delay A = GrvA: A06
Delay B = GrvB: B06
Xnob = FXA: RnGL
Ynob = FXB: RnGL
(EXP PED Heel) = ATK: 5 LN: 1/4
(EXP PED Toe) = ATK: 0 LN: 1/16
All out and straight-up glitching. The default settings demonstrate the variety of glitching effects available, and the glitching patterns for each processor are tossed out randomly. The effect can be subtle and yet surprising; depending on what you're playing, and what the PitchFactor "decides" at that particular moment. This can be used to add synthetic pick attacks to guitar.
Expression Pedal:
The expression pedal at the Heel increases the groove pattern attacks, while decreasing the time division rate. This position can audibly knock out some of the glitches, while emphasing the more rhythmic groove patterns. The Toe postion shifts back to the default preset settings.
February 4, 2013 at 6:45 pm #135201
MurfFilters
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = OFF
Pitch B = OFF
Delay A = GrvA: A06
Delay B = GrvB: B06
Depth / Key = ATK: 1
Xnob = FXA: FLT1
Ynob = FXB: FLT1
(EXP PED Heel) = FXA: FLT1 FXB: FLT1
(EXP PED Toe) = FXA: FLT5 FXB: FLT5
OK, so Moog isn't worried about going out of business with this preset. But the PitchFactor can provide a nice selection of sequenced filter effects. Identical filter patterns in each processor (plus the 100% wet signal) add a strong rhythmic presence to chained pedalboard effects. Pre- or post-distortion always gives filters more harmonic content to chew on. Pulling back the Mix knob to 50% pushes the filter effects towards the background.
Expression Pedal:
Five filter patterns are available through the range of the expression pedal. The limited number of positions makes it relatively easy to lock into any of the filter sequences with most expression pedals.
February 4, 2013 at 7:10 pm #135202
BowedReversal
Mix = WET:75
Pitch Mix = A10+B10
Pitch A = OFF
Pitch B = OFF
Delay A = GrvA: A02
Delay B = GrvB: B02
Xnob = FXA: OFF
Ynob = FXB: OFF
(EXP PED Heel) = ATK: -5 LN: 1/8
(EXP PED Toe) = ATK: 2 LN: 1/64
A slow attack preset that is vaguely reminiscent of up/down bow technique on strings, or a rhythmic reverse delay. Quite a different effect from using the PitchFactor's Crystals mode (more like soft tremolo effects or reversed ducking delays).
Expression Pedal:
The expression pedal flips the attack from a slow fade-in to mildly staccato. The rate of the repetitions increases at the same time, while maintaining a time division relationship to the current tempo. Use the expression pedal almost like you would a Leslie, with the rates moving slowly around the tempo.
March 20, 2013 at 9:47 pm #135307
I have about another dozen presets compiled along similar lines. Considering the self-imposed limitations – no primary focus on pitch shifting – I should be running out of inspiration any day now. The bonus for me is that I've uncovered all sorts of unusual pitch effects in the process. Enough for an entirely separate thread.
SynthiHiFliPedal
Mix = WET:50
Pitch Mix = A10+B10
Pitch A = FLTA: 100
Pitch B = FLTB: 25
Delay A = RES-A 10
Delay B = RES-B 10
(encoder) = OCTAVER / UNUSED
Depth / Key = DPTH: 0
Speed / Scale = SENS: 0
Xnob = FUZZ: 11
Ynob = oct …|| ……. fz
(EXP PED Heel) = FLTA: 100 FLTB: 25
(EXP PED Toe) = FLTA: 25 FLTB: 100
This is the one that got away from me. The Synthi Hi-Fli was a monstrous, fuzzy-buzzy effects box with an incredible phase filter modulation section. This preset is my attempt at reproducing some of the vocal-like WAW and MEOW settings. A big part of the Synthi control was in the dual footpedals, and it's no different here.
Expression Pedal:
You almost need a pumping expression pedal to get the desired effect here. I did try a MIDI LFO over a PED assignment, and the PitchFactor started freaking out. Moving the EXP PED from heel to toe (and back again) crosses the cutoff frequency of one resonant filter over the other. It's these crossing frequencies that combine for the vocalization effect.
March 20, 2013 at 10:11 pm #135308
UniVibrator
Mix = WET:50
Pitch Mix = A10+B10
Pitch A = A: UNISON
Pitch B = B: UNISON
Delay A = 1 ms.
Delay B = 2 ms.
(encoder) = HMODLTR / TMP: OFF
Depth / Key = DP: – 10c
Speed / Scale = SPD: 40
Xnob = RAMP-DN
Ynob = FBK: 5
(EXP PED Heel) = DP: -10c SPD: 40
(EXP PED Toe) = DP: -30c SPD: 80
This is about as close as I could come to a Univibe feel. More 'Vibrato' switch position than the phasey Chorus position. With a negative Depth setting, the sawtooth LFO is moving slight pitch variations in opposite directions. I used that to simulate the wobbly, asymmetric sine LFO in the original. Tiny delay times in each pitch shifter with minimal regeneration add to the complexity.
Expression Pedal:
The amplitude of the Univibe LFO increased as the speed gets faster. The expression pedal simulates this with higher depth. Of course, we're not simulating the distortions of the unique circuitry and LDR design. You'll have to add some of that at the input signal here.
March 20, 2013 at 10:34 pm #135309
PingPongLooper
Mix = WET:50
Pitch Mix = A10+B10
Pitch A = A: 1.000
Pitch B = B: 1.000
Delay A = 1000 ms.
Delay B = 2000 ms.
(encoder) = 910/949 / TMP: OFF
Xnob = FB-A: 100
Ynob = FB-B: 100
(EXP PED Heel) = FB-A: 100 FB-B: 100
(EXP PED Toe) = FB-A: 0 FB-B: 0
Set up as an infinite looper.The preset ping-pongs between left & right with a 1 second and 2 second delay (maximum). Blend in some variations using the REPEAT function (Flex switch in Play mode). The 200 ms. delay buffer repeats fold in to the looping delays.
Expression Pedal:
The pedal is configured to fade out the infinite looping at any setting other than full Heel. It controls the 'decay time' of the loops. Full Toe yields a single set of repeats. Rapid EXP PED movement (landing back at the Heel) retains some of the original loop, plus added input. Good for limited 'dubbing' and the introduction of fade-in phrases.
March 20, 2013 at 10:58 pm #135310
CirclePickFlip
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = ArpA: OFF
Pitch B = ArpB: OFF
Delay A = GrvA: A07
Delay B = GrvB: B02
Xnob = FXA: OFF
Ynob = FXB: OFF
(EXP PED Heel) = A10 + B0
(EXP PED Toe) = A0 + B10
Another two-pattern slicer preset. One sparse groove pattern combines with a more active pattern to produce a third 'pattern' with some characteristics of each. *Note: No guarantees in a mono routing using the expression pedal. For some reason, groove pattern B suffers from cancellation.
*Expression Pedal:
The expression pedal shifts the Pitch Mix between the A & B sides. Groove A can be used as a fake delay or slow tremolo. Groove B doubles the rate and varies the amplitude of alternating steps.
March 20, 2013 at 11:25 pm #135311
FakeFlanger
Mix = WET:50
Pitch Mix = A10+B10
Pitch A = A: 1.000
Pitch B = B: 1.000
Delay A = 0 ms.
Delay B = 0 ms.
Speed / Scale = MICRO
Xnob = FB-A: 75
Ynob = FB-B: 75
(EXP PED Heel) = FB-A: 50 FB-B: 50
(EXP PED Toe) = FB-A: 100 FB-B: 100
At default settings, this is a fairly subtle 'slow flanger' effect. The delay times are set to 0 milliseconds with significant amounts of feedback. Unintended pitch shifting from the MICRO mini-mode combines with processing delay regeneration to produce 'sweeps' in opposite directions. No direct control over the 'sweep rate'.
Expression Pedal:
At the Heel, the slow 'flanging' is barely noticeable. At full Toe, the feedback gets pushed into runaway oscillation. Full 'barberpole' effects travelling in two different directions are available near the Toe position. Midway is about where the default preset settings start out.
March 21, 2013 at 12:03 am #135312
EnvelopeChorus
Mix = WET:50
Pitch Mix = A10+B10
Pitch A = A: UNISON
Pitch B = B: UNISON
Delay A = 0 ms.
Delay B = 0 ms.
Depth / Key = DP: – 30c
Speed / Scale = SENS: 2 to 5*
Xnob = ENVELPE
Ynob = FBK: 0
(EXP PED Heel) = DP: -30c
(EXP PED Toe) = DP: 30c
*Set the envelope sensitivity in Speed / Scale to your playing style, or to the desired depth of chorusing. A setting of zero or 10 effectively knocks out the 'envelope' part of this preset.
The PitchFactor envelope appears to act on discrete input levels. That is, it doesn't seem to be an envelope follower in the strictest sense. One threshold level triggers the effect, and when the input drops below another threshold, the effect drops out suddenly, too. Still, there's quite a variety of responses to be found using the SENS: setting, in conjunction with your playing technique.
Expression Pedal:
Heel position has 30 cent pitch variations going both higher and lower (for a deeper 'chorusing' effect). More subtle variations can be found in the midrange of the pedal. The Toe position has pitch shifts both going upward, and the actual pitch variations become reinforced, and more noticeable.
March 27, 2013 at 7:17 pm #135317
GrainDelayPedal
Mix = WET: 25 – 50
Pitch Mix = A10+B10
Pitch A = A: 1.000
Pitch B = B: 1.000
Delay A = 50 ms.
Delay B = 50 ms.
Depth / Key = H949-1
Xnob = FBKA: 25
Ynob = FBKB: 25
(EXP PED Heel)* = A: 0 ms. B: 0 ms.
(EXP PED Toe)* = A: 2000 ms. B: 2000 ms.
At default settings, this is just a slapback echo with some decaying repeats. The first 949 algorithm adds some graininess to the flutter echoes. Legato playing results in almost a small room reverb response. Adjust the Mix setting to the desired depth of effect.
*Expression Pedal:
It's not necessary to get exact, identical settings for Delay A and Delay B; at either the Heel or Toe position. In fact, slight differences between the two delays enhances the granular reverberation effect. As the expression pedal moves from Heel to Toe, the control over the delay times slurs the repeats, and introduces short crossfade effects. Shorter delays are 'captured' in longer delays, and echoes appear to be arriving from many different directions.
March 27, 2013 at 7:39 pm #135318
FilterSplatter
Mix = WET: 50
Pitch Mix = A10+B10
Pitch A = ArpA: OFF
Pitch B = ArpB: OFF
Delay A = A:06
Delay B = B:06
(encoder) = PEGGIATR / TMP: OFF
Depth / Key = ATK: 10
Speed / Scale = LN: 450 ms.
Xnob = FXA: RnFL
Ynob = FXB: RnFL
(EXP PED Heel) = LN: 450 ms.
(EXP PED Toe) = LN: 75 ms.
Slow filter changes resembling a stepped wah effect. The sharp attack clips the filter to the first 1/10 of the 'step', with accents provided by the almost-steady groove pattern selections.
Expression Pedal:
The large increase in rate blurs the random filter patterns together, and stops just short of a gargling mess. Again, this is a preset that's not tied to tempo, and meant to be used in & around the current rhythmic pulse. Consider it an Alien Leslie effect, with the EXP PED ramping the effect up and down in speed.
March 27, 2013 at 7:57 pm #135319
MultiOctavia
Mix = WET: 80
Pitch Mix = A10+B10
Pitch A = FLTA: 0
Pitch B = FLTB: 50
Delay A = RES-A 10
Delay B = RES-B 10
Depth / Key = DPTH: 25
Speed / Scale = SENS: 100
Xnob = FUZZ: 7
Ynob = oct ……….|| fz
(EXP PED Heel) = oct ……….|| fz
(EXP PED Toe) = oct …..||….. fz
The Octaver algorithm's fuzz parameter has some of the squawky characteristics of the legendary Octavia pedal. As with the original, you'll hear more of the breakups & octave-up effects with double stops and with notes above the 7th fret. I didn't max this one out at Fuzz: 11 (nice touch, Eventide!). Rule of thumb: Cleaner input; more fuzz. Distorted input; less additional fuzz required.
Expression Pedal:
Here's where the 'multi' part comes in. The default preset is nearly all fuzz, with just a touch of the two suboctaves. The Toe position on the expression pedal mixes in resonant filter suboctaves in equal amounts. Use it to add a riffing bassline, or to break up the distortion-fest even more.
March 27, 2013 at 8:21 pm #135320
BinsonEchorec+
Mix = WET: 50
Pitch Mix = A10+B10
Pitch A = A: UNISON
Pitch B = B: UNISON
Delay A = D: 310 ms.
Delay B = . A . B . C . D
(encoder) = QUADVOX / TMP: OFF
Depth / Key = (any) N/A
Speed / Scale = (any) N/A
Xnob = C: UNISON
Ynob = D: UNISON
(EXP PED Heel) = D: 310 ms.
(EXP PED Toe) = D= 1240 ms.
Nothing earth-shattering here. This is simply my nod to one of the settings in the classic magnetic drum echo unit. The Quadravox algorithm doesn't provide for any feedback, but that's something you can derive from a downstream delay pedal. It does allow for useful spacing between delays, and here, the four 'playback heads' are equally spaced.
Expression Pedal:
The pedal is set up to quadruple the maximum delay time of the original (Toe position). For the adventurous, add Pitch A, B, C, & D to – 1 oct or – 2 oct., for a pitch-shifting 'tape stop' effect. As the delay time gets longer, the pitch of all four voices will drop along with it.
March 27, 2013 at 8:43 pm #135321
FeedbackCave
Mix = WET: 30 – 50
Pitch Mix = A10+B0
Pitch A = VxA: 250
Pitch B = VxB: 75
Delay A = AtkA: 2.0 S
Delay B = AtkB: 1.0 S
(encoder) = SYNTHZR / UNUSED
Depth / Key = RVB: 100
Speed / Scale = DCY: 10 S
Xnob = ASHP: SW
Ynob = BFLT: 100
(EXP PED Heel) = DCY: 10 S
(EXP PED Toe) = DCY: 0.0 S
– OR –
(EXP PED Heel) = RVB: 100
(EXP PED Toe) = RVB: 0
Simulated feedback buildup on every sustained note, To enhance the effect, this is fed into maximum reverb settings. For a parallel synth filter buildup, blend in the subtractive synthesizer by changing Pitch Mix to A10+B10.
Expression Pedal:
In the first EXP PED setting, moving the pedal adds some 'tape off the capstan' pitch effects to the trailing reverb decay. The second EXP PED setting fades out the reverb in the Toe position, for a more 'in-your-face' effect.
March 27, 2013 at 9:02 pm #135322
SynthWahPedal
Mix = WET: 50 – 100
Pitch Mix = A0+B10
Pitch A = VxA: 350
Pitch B = VxB: 50
Delay A = AtkA: 1.0 S
Delay B = AtkB: 0.0 S
Depth / Key = RVB: 25
Speed / Scale = DCY: 0.5 S
Xnob = ASHP: SW
Ynob = BFLT: 30
(EXP PED Heel) = BFT: 10
(EXP PED Toe) = BFT: 50
Now who can resist a wah-wah pedal? The default settings use the subtractive synth only, at a fixed-wah setting and no attack time. The lowpass filter carves a nice slice out of the moderate blend in Pitch B. The doubled effect is reinforced with just a touch of reverb.
Expression Pedal:
Pump away. The expression pedal programming stays within the lowpass filter range, but just above (at the Heel position) where the filter seems to knock out most of the input frequencies. Lower the Heel position to BFT: 0 for synth, bass, baritone, or other low frequency input.
March 27, 2013 at 9:30 pm #135323
ScratchLoopDelay
Mix = WET: 50
Pitch Mix = A10+B10
Pitch A = A: UNISON
Pitch B = B: UNISON
Delay A = A: 1/8
Delay B = B: 1/16
(encoder) = DIATONIC / TMP: ON
Xnob = FB-A: 75
Ynob = FB-B: 75
(EXP PED Heel) = B: 1/16
(EXP PED Toe) = B: 1/2
Quote:Xnob (Ynob)Controls level of Voice A (Voice B) feedback. The feedback delay length is Delay A or Delay B, whichever is longer.
The excerpt above (from the Diatonic section of the UM) explains the idea behind this preset. In the default settings, this is just a rapid ping-pong delay with a somewhat long decay time. But when you start to vary the delay times …
Expression Pedal:
By controlling the delay time in Delay B, the expression pedal shifts the feedback delay length between the 1/8 note static setting in Delay A, or the current expression pedal setting (if it's longer than an 1/8th note) in Delay B. Active use of the EXP PED yields scratching & stuttering delay effects. The feedback length remains sync'ed to tempo, but the changing divisions result in a very unique delay effect.
May 6, 2013 at 3:16 am #135369
brock:
SplicerGlitch
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = ArpA: OFF
Pitch B = ArpB: OFF
Delay A = GrvA: A05
Delay B = GrvB: B12
Xnob = FXA: GLT2
Ynob = FXB: GLT1
Expression Pedal:
Cool. I played around and change the following:
Delay B – B10
Attack – +3
X/Y Knobs – Glitch 1
May 4, 2014 at 9:48 pm #136582
Compiled in the H9 Control app. PitchFactor Programming – Other Effects
The complete Preset List file, plus 25 individual presets; all zipped together in the same download. I wanted to present some options that would work for both H9 & PF stompboxes, plus partial loading and preset sequencing options. No focus on pitch-based effects here. An expression pedal is almost required to get the most out of these presets.
8 Algorithms represented:
HarPeggiator – 12 presets
H910/949 – 4 presets
HarModulator – 2 presets
Synthonizer – 2 presets
Octaver – 2 presets
MicroPitch – 1 preset
QuadraVox – 1 preset
Diatonic – 1 preset
I was having some issues with getting exact values programmed in H9 Control 1.5.1. Let me know if any if anyone has trouble with an particular preset, or if any don't match the design descriptions above. All of them were programmed using a PitchFactor pedal, but should be interchangeable in an H9 / Core pedal (loaded with the same algorithms).
May 5, 2014 at 2:32 pm #136585
Hello ! Thank U so much for all these interesting presets.
I've got only a question : I've tried to installed them on my PF with H9 control. But it's impossible to load the complete Preset List file. And even if I tried each individual preset, some are ok but others no.
What can be the problem ?
Stef
May 5, 2014 at 3:12 pm #136586Quote:What can be the problem ?
I'm not sure. I thought that I tested all of it thoroughly, but your experience sounds like something major went wrong. I'll have to check everything back when I get the chance, and upload again (if necessary).
May 5, 2014 at 5:55 pm #136587
I've tried to install the Preset in my PitchFactor pedal following this method :
– I've download your files.
– H9 Control with my PF connected : I go to the "Settings" and "Import Preset or preset lists". I select one file and the answer is : "No data imported ! No presets or preset lists were found to import".
Maybe you know a better way to do it ?
Thanks for your help.
Stef
May 6, 2014 at 10:36 pm #136601
I'm running into the same issues that you are, Stax_911 (and I'm using the same roadmap to import). I found a reply on the forum from gkellum [Eventide] that mentioned the *.H9z format as a form of compressed zip file. It went on to suggest renaming *.H9z to *.zip, then extracting the preset or preset list. I'm sure that it referred to an ealier H9 Control version.
Since I compressed the file *twice* (zipping all of the H9z files together), maybe that corrupted something. Just moments ago, I downloaded my own upload, extracted it to a separate folder, and tried importing. The Preset List won't import – period, and some – but not all – presets import as singles. Let me try a few more things (including .syx file archiving from FactorLib), and see what I can come up with.
I'm tempted to delete the download until I sort things out, but perhaps Eventide can use it to analyze the export / import process from a user standpoint. Next time, though, the new upload won't "double-compress" the files. BTW: I exported everything from either the Preset or Preset Listing screen, not the Settings tab. I know of no other way to import (but drag-and-drop would certainly be welcome).
Thanks for your feedback, Stax_911. I'm going to get this download fixed. The irony is – I was waiting for PitchFactor support in H9 Control to compile all of these presets-on-paper. And when I tested the files before upload, I must have clicked on several of the presets that imported smoothly. Back to the virtual drawing board …
January 28, 2018 at 4:09 am #148255brock wrote:
I’m running into the same issues that you are, Stax_911 (and I’m using the same roadmap to import). I found a reply on the forum from gkellum [Eventide] that mentioned the *.H9z format as a form of compressed zip file. It went on to suggest renaming *.H9z to *.zip, then extracting the preset or preset list. I’m sure that it referred to an ealier H9 Control version.
Since I compressed the file *twice* (zipping all of the H9z files together), maybe that corrupted something. Just moments ago, I downloaded my own upload, extracted it to a separate folder, and tried importing. The Preset List won’t import – period, and some – but not all – presets import as singles. Let me try a few more things (including .syx file archiving from FactorLib), and see what I can come up with.
I’m tempted to delete the download until I sort things out, but perhaps Eventide can use it to analyze the export / import process from a user standpoint. Next time, though, the new upload won’t “double-compress” the files. BTW: I exported everything from either the Preset or Preset Listing screen, not the Settings tab. I know of no other way to import (but drag-and-drop would certainly be welcome).
Thanks for your feedback, Stax_911. I’m going to get this download fixed. The irony is – I was waiting for PitchFactor support in H9 Control to compile all of these presets-on-paper. And when I tested the files before upload, I must have clicked on several of the presets that imported smoothly. Back to the virtual drawing board …
Excuse me where i can download it?
January 30, 2018 at 4:39 pm #148289Gonzog wrote:Excuse me where i can download it?
This was quite a few years back. I don’t know if I’d trust the Preset Lists that I have archived. I’ll need to recompile & test a new List with the current software.
Hi Brock. Did you ever get arounf to this? 😉
May 7, 2014 at 7:23 am #136608
I agree with you Brock : Eventide could use your experience to improve the export / import process from a user standpoint with H9 Control. A drag-and-Drop interface would be more instinctive and easy to use.
Good luck and thank you for your work !
October 27, 2020 at 1:47 pm #156165
@brock H9 presetlist with these presetes would be pretty interesting to get 🙂
October 27, 2020 at 8:15 pm #156171
Uh, oh. Looks like I never followed through with this, after the initial failed attempt. Lots on my plate right now, but I will try to reconstruct these presets into a workable List, at some point. FWIW, I did recycle [read: tweak to death] a number of the HarPeggiator presets here in the SEQ VIEW Preset List.
February 13, 2022 at 3:46 pm #162166
Hola buenas tardes, me gustarÃa acceder a estos efectos, ene especial si tienes uno para usar en los solos de guitarra lead tipo blues, rock. Los archivos que compartiste ya no están disponibles, ¿podrÃas volverlos a compartir? Muchas gracias
April 2, 2023 at 4:26 am #170037
These are fantastic Brock. Thank you.
Am now looking for your thread with all the unusual Pitch effects you mentioned finding while creating these presets… 🙂 -
April 2, 2023 at 5:23 am #170038
Wow. The OG PitchFactor presets: blast from the past. The search function here has a mind of its own here lately. I’m having a lot of difficulty finding my own stuff here (broken links, zero results returned, etc.)
Funny this comes up now, as porting H9 Presets / Lists over to the H90 is high on my to-do list. Some of them ended up on the Preset Share site here (thanks to ET interns).
https://www.eventideaudio.com/presets/
I know that The Gear Page – Effects had a master thread with tons of preset ideas, for all the ‘Factor pedals. Contributed by others, I don’t have that link handy.
And I did find an old SeqView List from the HarPeggiator that might fit the bill. Some of them are modified from “Other Effects” on this thread.
https://www.dropbox.com/s/kf1l8c5saxxxivn/Seq%20View%20HarPegg.h9z?raw=1
April 3, 2023 at 1:33 am #170044
Thank you Brock.
Yes, if you do trip over any more old Pitchfactor settings while working with your flashy new H90, please throw us Pitchfactor/H9 peeps a bone and post any links.
The Pitchfactor is such a versatile and great pedal.
I’m doing my best to compile a list of all the useful/interesting/”famous” Pitchfactor settings I can find. This includes pitch based effects, the “Other” non pitch effects and settings that copy sounds used by our heroes and famous recordings.
Thanks again Brock (and others who have contributed settings), your technical abilities and time are always appreciated,
Andrew.
