PitchFactor Suddenly Not Recognizing Expression Pedal(s)
Home Forums Products Stompboxes PitchFactor Suddenly Not Recognizing Expression Pedal(s)
    • #106524
      gspin
      This problem has suddenly arisen.  I was using an EV-5 and a M-Audio at different points, now all of a sudden the PF won't recognize either of them.  My TimeFactor has no problem with either pedal.
      What could the issue be?  I've tried searching for a solution in the Manual with no success.
      Many thanks in advance for any suggestions.
      cheers
      gspin
    • #119222
      Make sure Utility/PDLOCK is set to off. Otherwise check cables and connections.
    • #119242
      gspin
      Thanks Nickrose… problem solved
