Home › Forums › Products › Stompboxes › PitchFactor Whammy MIDI Problem
August 15, 2011 at 10:49 pm #108061
ChrisJordan
ParticipantOk, I may be doing something stupid, but here goes. I am trying to use my PF as a whammy pedal, which I have done before; however, I am not getting any pitch bend.
- I have V3.0 (19) firmware
- I'm on Pitchflex
- The display on the PF is showing it's receiving a signal from the MIDI is PDL 0 to PDL 100 – so I know the signal is getting there.
- WET:DRY is 100 Wet
- A(h) is at Unison – A(t) is at +1 Oct
- B(t) and B(h) are off
I am at a loss.
Thanks for any help you can give.
August 15, 2011 at 11:37 pm #122540
ParticipantI just tried your exact settings, and swept from unison up an octave using MIDI CC -> PED. I'm also at a loss. From your description, even the MIDI channel is set correctly. Have you verified that your GLOBAL -> MIX setting is OFF? Can you 'flex' an octave in Play mode using the middle switch (or an expression pedal)? That's all I can think of at the moment.
I like to move the Pitch Mix over to A10 + B0 in a single shifter patch like this. If it's set to A10 + B10, you'll hear a reduction in amplitude. A0 + B10, you'd hear … no output. But you should still hear some pitch shift at anything but this extreme.
August 16, 2011 at 3:21 pm #122543
I believe this is a bug. The workaround is to just plug a "dummy" jack into the expression pedal input on the back. After you do this, you should be able to use expression pedal over MIDI in Pitchflex. This is the only algorithm this bug affects. Try this and let me know if it works.
Thanks,
Russ
August 16, 2011 at 3:39 pm #133720
ChrisJordan
ParticipantThe dummy jack has fixed it. Thank you very much. It was infuriating as I love this little stomper. It's a taken up a big space in my heart.
August 16, 2011 at 4:01 pm #133721
ChrisJordan
ParticipantThis has fixed it a treat. Thank you very much.
Chris
August 16, 2011 at 9:57 pm #133723
ParticipantI had forgotten all about this little PitchFlex 'anomaly'. I did indeed have an expression pedal plugged in when I ran through your posted settings.
October 9, 2011 at 7:08 am #122730
Atomicunderware
ParticipantAny chance of a patch to fix this bug? I remember it was an issue when I first had the TF and MF, but updates fixed it. Now that I have just updated to the new firmware the issue that was never there on the PF has appeared! I don't want to have to revert to the older version which didn't have the problem, but less features, and having a jack plugged in is not an acceptable solution.
