Home › Forums › Products › Stompboxes › Pitchfactor – what does expression pedal do?
September 23, 2009 at 1:36 am #106458
siriusbliss
ParticipantJust purchased a PF, but am wondering what some of the default settings are for the expression pedal.
pitchbend? modulation? chord change? scale change? tempo change? etc.
Greg
September 23, 2009 at 11:20 am #119075
badmelonfarmer
Participantif you look at the downloadable preset chart it shows what the expression pedal does for each preset.
BUT you can assign the expression pedal to control any of the rotary knobs and more than one.
so yes it can do PitchBend etc
Cheers
BMF
September 23, 2009 at 6:26 pm #119078
siriusbliss
ParticipantYes, I've been reading through the preset chart.
I'd like to do harmonically correct pitch-bends (after learning), and leave all the expression control of modulation and delays to my TimeFactor.
Thanks,
Greg
September 24, 2009 at 3:07 pm #130213
to do this, create a preset in Diatonic or Quadravox that you like.
Then set the expression pedal to control the pitch shift amount via
following the steps in the manual. That should get you there. -
September 24, 2009 at 7:02 pm #130215
siriusbliss
ParticipantThank you,
Greg
September 28, 2009 at 9:48 am #119114
jufros
MemberCan you explain how you actually get the Pitchfactor to recognize a MIDI expression pedal properly?
September 29, 2009 at 3:23 pm #119125
You'll have to read the manual, I'm afraid. The LEARN feature is useful.
September 29, 2009 at 7:24 pm #130260
siriusbliss
ParticipantYes, I posted before downloading the pdf manual.
My new unit hasn't arrived yet.
And yes, I'm mainly interested in the learn function.
Thanks,
Greg
September 29, 2009 at 7:33 pm #130261
Once you have it in learn mode (after reading the manual), you should just need to wiggle the MIDI pedal, and the unit will do the rest itself.
