PitdcFactor presets with Exp Pedal settings
Home Forums Products Stompboxes PitdcFactor presets with Exp Pedal settings
    • #108008
      roverdog
      Here is my file of the PitchFactor 3.0 Presets.  You will have to use your tab to get the columns up.  Unfortunately I lost the column alignment when I saved the spreadsheet as a .txt file so that I could post it to the forum.
      Steve
    • #122443
      Thanks for all of your hard work.  Deconstructing all of the expression pedal assignments is no easy task.  I (for one) have replaced or modified all of the factory presets.  As much as I've tried to rename them with distinct file names, I still have this nagging feeling that I've missed a few.
      This is a great guide for questions on the forum, or references to the original presets for those who may or may not  'tweak' their stompboxes as much.  As far as formatting goes, have you had a look at Timothy Hill's uploaded templates (found here)?
